Question about Coleman Powermate Powermate 5000W Generator
Mtor runs fine no power to outlet - Coleman Powermate Powermate 5000W Generator
  • 5,603 Answers
The field has become demagnetised.
Try hints at this site:
http://www.endtimesreport.com/dead_gen.html
Posted on Jan 04, 2011
Blower mtor on 1997 Chevy 1/2 ton 4wd runs real slow or not at all,some times it speeds up to near normal speed.
Yes, the blower motor is bad, replace it. This is exactly what you say, brushes are worn.
Dec 04, 2013 | Cars & Trucks
I have (7) 20W bulbs on a newly wired line running on a brand new 200W Malibu transformer, worked fine for 2 days and now it's tripping the reset button - Any suggestions ??
1) Copy following link for malibu power pack tips for longer transformer life:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Two plug choices on each outlet, Plug power pack into other outlet on receptacle.
Inspect for damage on outdoor outlet.
Replace outdoor outlet, and do not use quick connects. Connect wire directly to screws on side of device.
Replace GFCI outlet.
Feb 01, 2013 | Malibu Intermatic Inc. ML121RT Low...
Mitsubishi MGE 6700 generator. Starts and runs fine, but no longer putting out power. What would it cost to repair this issue?
These generators have a GFI outlet on them, and they do fail. I would suggest you check all output circuits and see if you have any output. If so, pull the GFI and see if it is getting power to the outlet. If so, replace the outlet.
Feb 20, 2011 | NEC Mitsubishi MGE 4000 Generator ROU...
Our Hoover U8172-900 brush motor is not working. Do you have a wiring diagram so I can determine if the motor circuit board is the problem or the motor?
No diagrram is necessary unless you have dismandled.
Check if the brushes are touching the mtor commutator. If not you can easily remove both the brushes and polish the surface evenly .Insert only after cleaning the motor commutator till the copper shines.
Use can check for the continuity of the brushes to show that the armature is working Ok.
Now check the filed winding. Both the windiings must snot show any leak or short to the body. If so the motor is fault.
If field is ok with the resistance check then check for power supply to mtor when switch is triggered . If not check cord and switch.
Hope this tip helps.
Aug 29, 2010 | Hoover Vacuums
My new Miller Bobcat has low amperage on 120 volt outlet.
Increase your idle setting on the 1/8" threaded rod protruding to the left of the carburetor until V= 125. Then run your drill. Actuating the drill should call the throttle solenoid to open up to produce more power.
May 12, 2010 | Miller Electric Manufacturing Electric...
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
No power from either front or back. Checked the CIG fuse under the dash and it's fine
thier are 3 fuses that run you power outlets one is the cigar fuse a red 10 amp then you have the ACC fuse 7.5 amp brown and then you have the blue 15 amp power outlet fuse they are all located in the drivers side fuse box where you allready checked the cigar fuse
May 29, 2009 | 2003 Toyota 4Runner
Coleman Powermate Powermate 5000W Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
