Washer will not agitate when washing,however does spin on the spin cycle. Whats wrong?
Try and unscrew the top plastic piece of the agitator, inside there are some small plastic pieces that wear out, i picked mine up at ace hardware for a buck or two. good luck
Posted on Jan 04, 2011
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Washer won't spin or agitate
what brand? model name and number would help. it might just need reset. or could be other problem.
Jan 26, 2014 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Not spinning or agitating
Most likely you have a bad belt or a defective lid switch.
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
You can hear the washing machine spinning but the tub dos not spin whats wrong?
Good day,
Go back and start a wash cycle. When it fills and starts running check to see if the agitator is working. If not then go here for a detailed explanation on repairing.
http://repair2000.com/coupling.html
It's a tedious job, but with a lot of patience it can be done.
If the agitator in the wash cycle is working normally, then you have a major problem, and would require a service tech. Not cheap.
Dec 01, 2009 | Roper RAS6233KQ Top Load Washer
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Not running through cycle
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Good Luck!!!
May 06, 2009 | Indesit WA 115 Front Load Washer
Washer won't agitate
does it immediately do the draining cycle?
Feb 20, 2008 | Kenmore 80754 Top Load Stacked Washer /...
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
