Toshiba 65HM167 yellow lights flashing, will not power up.
Reinstall the lamp access door. The maual clearly states that the door must be attached or the safety interlock switch will not be activated.
Posted on Dec 31, 2009
Yellow blinking light on toshiba tv
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Jul 05, 2015 | Toshiba 65HM167 65" Projection Television
Ballast problem?
The ballast is possible if it does not light the lamp even for a few moments----about the lamp= generic bulb or a OEM Toshiba lamp unit?
Aug 27, 2012 | Toshiba 65HM167 65" Projection Television
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Yellow light blinking on tv will now come on
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Apr 26, 2010 | Toshiba 65HM167 65" Projection Television
My Toshiba Model no. 65HM167 does not power up. The lamp light on front of t.v. flashes and thats about it. I replaced the lamp but still no go. Help.
CK the Lamp Fan if it stops running Lamp will not light and if thats ok Ballast Board it is what turns Lamp on!
Visit Encompass Parts Distrubtion for Parts List and numbers 1-800-638-3328
Mar 23, 2010 | Toshiba 65HM167 65" Projection Television
Tv will not turn on. lamp light is flashing 3 times. i put a new lamp in it and have the same problem
The boot data is corrupted. Download the firmware update from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
Feb 24, 2010 | Toshiba 65HM167 65" Projection Television
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Yellow blinking light after power went down
Unplug the unit for 15 minutes then plug it back. This will allow the microprocessor to be reset. Upon plugging it back, press and hold the power button on the remote.
Nov 07, 2009 | Toshiba 65HM167 65" Projection Television
Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Jun 22, 2009 | Toshiba 65HM167 65" Projection Television
Cant find a ballast
The ballast is actually a switch mode power supply that powers the lamp. It is an
integral part of the light engine and is not replaceable. The light engine has a price
tag of $950. If you replaced the lamp with an after market one and not the Toshiba
lamp you can experience the same problem. Some of the after market lamps will
not fire at the same voltage as the Toshiba. The blue led will come on solid and the
yellow blinking. It will try to start 8 times then give up.
Charlie
Sep 29, 2008 | Toshiba 65HM167 65" Projection Television
Televison & Video Logo
552 people viewed this question
Top Televison & Video Experts
