Question about Canon imageRUNNER C3380i Color Copier
I have a canon image runner c3380i. I replaced the waste toner container and it still keeps giving the replacement error. How do i get past this to start making copies?
  • 34 Answers
Inside where you put the waste container at the top is a black sensor. clean it
Posted on Jan 04, 2011
  • itzvirag Jan 04, 2011
    Thanks for your comment. I am assuming you are referring to the black sensor in which that clear part of the waste toner slides to. I wiped it with kleenex and it still didn't work. Is there a "right" way to clean it?
Replace waste toner container imagerunner c7065
On the right side of the copier towards the back lower corner you will find the cover to the waste toner tank, a single screw holds it in place, remove the cover panel, behind it is a large plastic bottle pull it out empty it put it back in, pay attention on how it comes out so you will be able to replace it, may have to pull the lid holder out first.
To clear the error after changing the waste toner container on Canon C7065 Image Runner Advance, from the control panel, click on the setting/registeration button. Logon to the machine, you will need admin ID # and pin #, Once logged in pick adjustment/maintenance, on the next screen pick maintenance, then use the arrow key and chose page 2 on the next screen touch initalize after waste toner replacement.
Apr 01, 2012 | Office Equipment & Supplies
Error code E-000013-0000 on a Canon Image Runner 5000
e-000013, it is all about waste toner.
possibility :
- waste toner case was detecred full.
- The PLL lock is released because waste toner motor is locked up, etc.
- The micro switch employed to detect clogging of waste toner is activated.
the position behind-below of copier.
open the beck cover and you ll see it.
the waste toner case
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
Error is E000019-0000
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
Sep 22, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon Image runner 2830
Error code E000019-0000 is a waste toner full error, so to get rid of this error you remove the waste toner bottle which is located left rear side of the machine and dispose the waste toner and dont forget to clean the neck of the bottle because the waste toner might obstract the toner sensor passege and then switch off then on and you are up and runin
Mar 13, 2010 | Canon Office Equipment & Supplies
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
I cannot find the location of the waste toner bottle.
On iR 2200, the waste toner container is located from left side of copier. To be precise, on left side are door with handle (wich is opend to reach paper in fixing assy or duplex), beneath this door ( left lower section from the door ) is small cover with one screw, when you remove it you will be able to see waste toner container. Its a plastic botlle, remove it clean it and dry it.
Feb 28, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
Product : imageRUNNER C2880 / C3380 Title : E025 sub code 0002
Problem :
The machine is giving an error code of E025 with a sub code of 0002 indicating an error with the cyan toner motor.
Solution :
Replace the Process Kit Relay PCB. Item 58 of the Hopper Assembly circled below, part number FM2-8266-000. NOTE: the service manual refers to this part as the Process Kit Relay PCB while the parts catalog calls it the Connecting PCB Unit.
getfile.asp?rid=24817
Apr 27, 2009 | Office Equipment & Supplies
Waste toner
Turn off the copier. Remove the lower left panel on the left side of the copier, then pull out the plastic container and empty it. Reinstall the container and cover then turn the machine back on.
Apr 08, 2009 | Canon imageRUNNER C3170U Color Copier
IMAGE RUNNER 2200
First, turn off all power to the copier.When looking at the front of the machine, turn the machine counter clockwise so you are now looking at the left side of the machine, go to the lower left hand corner of the left side of the machine. Loosen the screw to the panel which is about 4" wide x 10" high. The screw is in the upper right hand corner. After you remove the panel, carefully slide out the toner waste container, empty it, and rinse it clean with plain water, wipe the outside clean, blow out the machine with canned air, replace waste container, put panel back on and power up your copier.
Nov 06, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Cannon Image Runner 5570
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Nov 16, 2007 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER C3380i Color Copier Logo
343 people viewed this question
old marine
old marine
