Question about Refrigerators
Will not stay in cooling mode and compressor shuts down
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 04, 2011
Model 57915
THE RELAY MAY BE FROZEN TIGHT. SOME RELAYS GET HOT AND AND STAY WITH THE CONTACTS WELDED.
Jun 19, 2015 | Heating & Cooling
Central heating&cooling
sounds like your compressor is getting hot and shutting down have you washed your outside condenser coil? Could be dirty causeing high head pressure and shuts your compressor down. Try washing your condenser coil I think this will help you. If not you may be low on charge of Freon.
Aug 17, 2014 | Rheem 13AJN30A01 Central Air Conditioner
Air conditioning on 1988 cadillac
this system has a shut down mode when it detects freon gas is low. if the system is cooling the car just by being reset then you may have a faulty high or low pressure switch, but if it is reset and turned on and is not cooling the car correctly then that is why is keeps going into shut down mode. this was set up to avoid a/c compressor damage, this wont allow the compressor to run and over hat itself due to low or overcharge in the system.
the first step would be to evacuate the system and apply a vacuum for 45min. then recharge the system added oil and dye, (dye is used to find leaks if system looses freon.) then run a/c and do a vent temp. test, making sure compressor pressures are good and vent temp is good, at this time shut down car and see if it goes into shut down mode. if it does then have the switches tested and check the compressor clutch, ohm it. start with this, if the system takes a few days to go into safe mode then i would say there is a leak and it is doing its job, now you will need the glasses and blue light to locate your leak.
Jun 09, 2013 | Cars & Trucks
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Lennox outside unit fan will not stay running unless i reset the red button
You should replaced the fan motor along with capicator
Jan 10, 2018 | Heating & Cooling
Overheating
I am not an expert on Mazda vehicles but sounds like your fan temperature sensor is not working properly. My fan comes on low speed when the temp hits 205 and goes to high speed at 220 or when the air conditioning is on. You had better get it checked by your dealer or service tech.
Aug 03, 2009 | Mazda MPV Cars & Trucks
Keeps running after shutting off-does not react to temperature co
it is normal for the system to run on its own without being turned on...the compressor motor needs to cool down and will run in an unloaded state. feel the back of the unit while its running and you will notice the amount of heat the motor generates. let it run.
Jun 18, 2009 | Heating & Cooling
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Ruud 5-ton 10 SEER heat pump compressor turns off after 20 minut
First turn it to cool and see how cold the big cooper line is if it is not real cold you could be low on freon but if it is cold your compressor is bad
Nov 12, 2008 | Heating & Cooling
Every 2 mins the compressor tries to go on and after 15 seconds stops.
If the compressor tries to go on every two minutes, then the relay is functioning.
1. If the compressor has failed, it might be getting hot and tripping the thermal overload to shut itself down. It will cycle like you say and will be unable to cool the fridge.
2.It's also possible that you have lost refrigerant from the system. When the compressor goes on, the pressure drops below a threshold value. The system sees that there is not enough pressure, and shuts down. Once the pressure rebuilds, it tries again.
3. If the fins in the rear of the fridge are clogged with dust/debris, the system will not be efficient enough to cool. I doubt this is the case as the compressor would generally just stay on for a long time... longer than 2 minutes.
Try turning the thermostat to the coldest setting possible for both the fridge and the freezer. If the unit still cycles off after 2 minutes, consider repair.
Mar 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
