Question about Bunn Dual TF DBC Coffee Maker
I have a dual tf dbc that has a water dispensing problem. The left half of the machine correctly dispenses the proper amount of water per brew recipe. The right half of the machine consistently dispenses water at half the rate assigned in the recipe. I have checked the flow rate and adjusted it higher with no change in the amount of water dispensed. The machine has been in operation for only two months. Answers?
    President:
  • 1,618 Answers
Sounds like a solenoid blockage and or the spray head holes are blocked.
Posted on Jan 05, 2011
My Keurig SS-700 will initially dispense coffee but stops after a few seconds
use clr and run it through bthe machine 50/50 rinse with vinager then water,3 cycles
May 27, 2015 | Cuisinart SS700 Keurig Single Serve...
Only brewing half of decanter
Remove and clean the spray head above the filter basket. If it still under fills, there could be a problem with the dispense solenoid valve.
Apr 22, 2014 | Bunn Dual SH DBC
The hot water spout is not dispensing water properly. The flow rate is low. its not the spout itself, I've replaced it... The water line appears to be unobstructed... Any idea what could be blocking the...
Mineral build up, remove the top panel and clear hose to boiler, you will have to turn machine off and remove hose at boiler and use a small screwdriver to clear fitting on boiler.
Nov 24, 2010 | Bunn Dual TF DBC Coffee Maker
How do i adjust the water flow from the hot water dispenser? I need it to come out faster.
If your talking about the hot water faucet the flow rate can't be adjusted.There may be a blockage from lime at the tank fitting.You will need to clean fitting of lime.
Nov 06, 2010 | Bunn Dual TF DBC Coffee Maker
How many ounces or cups of ground coffee is standard for a Bunn dual dbc to make a 1/2 gallon of brewed coffee?
For a half gallon of brewed coffee you should start with a "volume" measure of 10 oz. The reason I recommend a volume measure is because the weight could be completely different using light roast or dark roast coffees. Brewing by volume you can have consistency throughout. The main object is to have the same surface area of grounds for your brewing. The 10 oz. volume should equal between 3.75 and 4.25 ounces by weight. Adjust by taste to your palette but don't sway too low in amount of grounds, otherwise you will stand to "over-extract" and your coffee will taste bitter and will have no body or mouth-feel.
Oct 12, 2010 | Bunn Dual SH DBC
I have a Bunn Dual SH coffee brewer that does not dispense the same amount of coffee every time
The problem is either the liquid control board or there is something blocking the solenoid, or drawing water from the same line pressure. Also check the sprayhead for buildup.
Oct 26, 2009 | Bunn Dual SH DBC Coffee Maker
Water left in fabric dispenser after load
The dispensers work by the siphon principle. You load the softener and at the proper time, the machine diverts water to the softener cup raising the level. In the softener cup, there is a tube loosely covered with a cap. When the level in the softener cup is raised high enough, a siphon effect is started and the softener is pulled from the cup into the washer. This will continue until the water quits flowing and air gets under tha cap, breaking the siphon. The amount of water remaining in the cup is dependent on the level of the cap, and the amount of residual water remaining in the dispenser fill tube once the siphon effect is broken. You can see this effect for yourself: take a measuring cup and slowly pour water into the softener cup, raising the level above the max line. When the level gets high enough, the contents of the cup will dispense. You can remove the cover cap that is a part of the dispenser and clean it; it will help. Removing the entire tray and cleaning all of the tubes and the cap assembly will also help. The only other thing that can be done is to change the dispensing supply valve, as it sounds like there may be some leak by after the fabric softener is dispensed. Having residual water isn't really hurting anything. It's only water, and the machine has dispensed the softener! Try the cleaning part first as this usually corrects the issue, and then the repair technician if it still bothers you. For as much as the extnded warranty costs, you should be completely satisfied with your machine.
Best regards, --W/D--
Sep 13, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Cleaning the thermos on the BUNN single TF DBC
For the thermos you can use a small amount of purocaff and fill the thermos with hot water, let sit over night then rinse with cold water a few times to clean you can also use a soft brush to clean while the purocaff is in thermos. Clean around the showerhead with a clean towel, or you can use a filter with a little purocaff and brew into thermos and clean both in one shot.
Mar 23, 2009 | Bunn BREWWISE Single TF DBC Coffee Maker
How do I set the amount of water dispensed w/ Bunn CDBCF35 Digita
Hello. You will need to set the timer, this is done, if the settings are not locked out, using the brew button on the front, holding it until 3 clicks are heard, then just let it brew until you are satisfied with the level, and turn the brew off. This does take a little practice, and may need to be done repeatedly, and you should be prepared for overflowing, just in case :) Here is a link to your manual, please read the section that is for your unit, as it is for several.
http://www.bunnomatic.com/pdfs/commercial/manuals/29079.0000.pdf
Hope that helped, thank you.
Mar 03, 2009 | Bunn CDBCF35 (DBC) Digital Brewer Control
LG 2077 CW-has IE code issue as well as soap dispensing problems
IE is an inlet error indicating that the machine has not filled up to the correct water level within 10 minutes. Could be a bad inlet valve, low water pressure or a problem with the inlet hoses (do not use anti flood hoses with these machines, use only the included fill hoses).
It sounds like all of your problems lie with the water fill. If the dispenser compartments do not get water added to them then the soap, bleach, and/or softener will not dispense properly. Then it will still be present and may dispense on the next load instead.
It is also VERY important that you use an HE (high efficiency) detergent and the correct amount (2-3 tablespoons per load). Otherwise you could end up with oversudsing issues which can also keep the bleach from dispensing properly.
Also make sure to not use GEL bleach, GEL detergent or GEL softener as they are too heavy and will not dispense properly. If all of these recommendations do not help then there is a definite issue with the incoming water supply from the inlet valves (especially if the IE errors continue). In that case you will need a technician to check the inlet valves inside the machine.
Hope this helps, please rate my solution.
Jan 04, 2009 | LG WM-2077C Front Load Washer
Bunn Dual TF DBC Coffee Maker Logo
295 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
