Question about Honeywell HZ-680 Oil Filled Radiator Heater
It is not heating as strong as it recently was and this morning I found a small leak of oil on the hardwood floor. Can it be repaired and is it ok to use?
  • 6,927 Answers
If it is leaking ,when it gets low enough,the heating elements will burn up,it is best to trow it away,and buy a new one,getting parts for these are an act of congress and you can buy a new one for the cost of repairs,and the tanks can not be fixed,or filled.
Posted on Jan 04, 2011
How to use on hardwood floors
yes but if they are laminate dont use wet cleaner vac
Jan 08, 2018 | Vacuums
Toyota corolla smells like gas after its been parked?
sounds like u have a gas leak somewhere. check under the car on the floor see if u can see anything leaking also trace the gas line from the tank to the motor for leaks. u need to get this fixed before u have a fire.
Apr 05, 2014 | 1995 Toyota Corolla
An oily substance is leaking through my floor
ac has a oil charge sprinkler systems do not
Oct 16, 2017 | Cars & Trucks
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
I had a Honeywell Oil Filled Radiator HZ 680....I discovered ti was leaking , so I immediately threw it away. However, it appears that the oil leaked onto my hardwood floors....and it seems it spread. I...
You can use a degreaser. The spell will not harm you, just so you know. These heaters are filled with oil that will not harm people from the fumes. Most likely what you are smelling is the part of the oil that burned on the element as it was leaking out. Now as for your floors, I am sorry to hear this but you can replace that portion or call a certified floor repair person that specializes in hard wood floors.
Hope this helps.
Jan 28, 2011 | Heating & Cooling
I have oak floor and there are scuff marks. Is it...
If you have a wax finish you can buff out scuffs with just a cloth. for polyurethane, do not use water. use the cleaner with a soft terry cloth. to much presure can make it worse.you can also use a small amount of paint thinner on polyurethane. make sure you remove excess with floor cleaner.
May 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Roomba has been scratching my hardwood floors.
My brand new Rhoomba worked perfect the first time. The second time using it, I was aghast to come home to the same issue.
My marble floors now have long scratches across the wide expanses of floor. In the areas where the rhoomba (I witnessed it doing this motion the first time I let it clean) does those small geometric patterns like in confined areas, those same geometric patterns appeared scratched into my marble floors in my condo!!!!
What's worse? They do not intend to do anything to repair the damage....just refund my money.
R---I---P O----F----F! DO NOT BUY ONE!!!!!!!
Jan 31, 2010 | iRobot Roomba 560 Robotic Vacuum
My Sub-Zero 550 is on a wood flooring that is experiencing severe water warping. I checked for leaks from the fridge at the water feed line to the water valve. The drain pan is ok Is there another...
Are you sure that it is water warping and not the heat from the compressor under the unit? Some wood flooring, such as laminate flooring is made up of pressed wood that is glued together and the heat may be warping the glue.
Aug 29, 2009 | Sub-Zero Bottom Freezer Refrigerator
Soleus A/C unit is leaking water out of drain plug
it is working well, possibly has a bad sensor to tell you it's full but put a permanent drain on, run it in the sink or dump it more often. just means it's pulling out excessive amounts of moisture
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Nov 03, 2017 | Soleus KY-34 Portable Air Conditioner
Honeywell HZ-680 Oil Filled Radiator Heater Logo
110 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
