WHERE IS THE FURNACE PILOT LIGHT FOR THIS MODEL?
    Problem Solver:
  • 5 Answers
Generaly in the midle of the unit... Look fo an aluminum tube running from the gas valve to the pilot line general following a copper tube to the thermocouple.....Standing pilot?....
Posted on Jan 04, 2011
What do I need to do to lite my heater after a summer rest?
How to Light a Furnace Pilot Light Here, we'll explain the basic steps for re-lighting the pilot light of a gas furnace.
#1: Locate the Instructions Label on Your Furnace
Every furnace should have a label on it that tells you how to light a furnace. Sometimes, however, the printing may be small or the furnace area may be dark. In these cases, the label may be difficult to read. Keeping the following instructions near your furnace or in another safe spot where they can be located easily will make the task much easier.
#2: Find Pilot Light and Components
Near the bottom of your furnace is a switch that normally says "Pilot," "On" and "Off." Find this switch and turn it to the "Off" position. Wait at least five minutes. This is important because it gives the gas time to dissipate, which is necessary to avoid possibly starting a fire. While you are waiting, take note of the location of the reset button, which should be near the dial you just turned to "Off."
#3: Re-Light the Pilot Light
Once the gas has had time to dissipate, turn the knob to "Pilot." Then, hold down the "Reset" button and bring the flame of a long lighter close to the pilot light opening. This should light the furnace pilot light. Once you are sure the pilot light is on, release your pressure on the reset button.
Sometimes, seeing a job bein
Oct 28, 2017 | Heating & Cooling
How do I light my gas furnace
light my gas furnace Marbillw, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to turn your furnace pilot light on
How to Light Furnace Pilot Light HowStuffWorks
http://www.centralhtg.com/blog/how-to-light-a-furnace
How to Light Pilot Light
Jun 08, 2016 | Heating & Cooling
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
How do I light an Intertherm furnace Model Number MG 068A?
Hello, if the Furnace is a standing pilot then turn the knob on the gas valve to pilot, you will hear a hissing sound then use a match or a lighter to light it at the thermoouple. Hold the knob on pilot for about 30 seconds and then turn the knob to gas and burners should ignite.
Nov 11, 2011 | Heating & Cooling
How do you lite the pilot lite on a Rheem Gas Furnace Model #rgma-125a
If I recall correctly, model number Rheem furnace you listed has electronic ignition to light the pilot, when the home's thermostat calls for heat. Is this what you're having a problem with?
Mar 11, 2011 | Heating & Cooling
I have a a Ruud furnance, model UGAC 095c. The problem is the pilot light goes out once or twice a day or late night. The thermacouple was replaced, new filter also. I also observed the pilot light and lit...
check the thermocouple is tight in to the valve , condtion of thermocouple could need changing , is pilot stong blue flame could need cleaning .
Feb 06, 2011 | Heating & Cooling
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
