I have an Electrolux split air-con, have no manual, want to just have fan on without the air on ,do I fix it no DRY Mode regards
  • 2,133 Answers
Fan mode only, you can control low/med/high speed. In dry mode with low fan, it cut in and off air-con for five minutes frequently.
Posted on Jan 04, 2011
I have a kelvinator Electrolux split air con model r51k/bge it doesn't seem to keep coolits set on 17 and the control says cool the fan says high but no cold air comes out wat could be the pro
many reasons could be there, check that the outdoor fan working or not if yes my be the compressors is tripping, if no, check the volt for outdoor, check the gas and the leakage
Nov 21, 2014 | Electrolux Heating & Cooling
How to use and set temp for dry mode on panasonic split system
I do not understand what is the problem, hit the button mode and goes to the mark which is the DRY (a drop). Usually has its own function if the outside temperature is below 13 degrees C did not work, if this happens;
Oct 24, 2011 | Heating & Cooling
Need to change from cooling to heating for a Kelvinator KSR27G split sys air con. Have tried ourselves using the remote, but we feel it is not operating correctly. No manual came with it when we purchased...
The cooling symbol on the remote is generally an "icicle" , the heating is a symbol of a blazing sun. Make sure you have selected the right mode. Also check the filters... if they are dirty, you wont get decent heating from any air con.. cheers,
BTW, I believe that electrolux have a site you can download instruction books.
Jul 14, 2011 | Heating & Cooling
I have lost my manual for my bio tech plus air con. my air doesnt seem to be cold at all, not sure if i have right setting, on the remote there is a sun, snowflake auto and i think a raindrop, which should...
Dear friend, find below symbols for mode setting. For cool keep minimum 3 degree less than room temp and heat keep minimum 3 degree higher than room temp. Dry mode will help you only in wintertime. Thanks.
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Feb 01, 2011 | Heating & Cooling
I av lost my manual. Pls kindly give me details on each of the samsung split AC 5way. I mean what each symbol means
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
4. Sun- Heat
Jan 19, 2011 | Heating & Cooling
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Hi i have recently purchased an amcor sPLIT UNIT AND CAN NOT GET THE HEAT TO WORK AND DO YOU HAVER ANY SUGGESTIONS AND PRESUME IT IS A SETTING i AM NOT CORRECTLY PRESSING ? rEGARDS cRAIG
dear sir
please first make turn on your electrical supply for air con
and then use remote controller and find out there heat mode and select it then make your air con on heat mode ..
i hope it will work on heat mode
hope answer the question
thank you
please vote!
Sep 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
