Question about Pioneer DEH3200UB w USB Input iPod control Car CD MP3 Player
I am trying to install a Pioneer 3200UB. I purchased the harness and have power to the radio. I have no sound comming out of three of the speakers and a faint sound out of the fourth. Any suggestions.
Try Checking to see if you Have the positive and Negatives for the speaker's hooked up right, and make sure that you don't have a Negative to a front speaker and A positive going to a rear Speaker
Posted on Jan 14, 2011
Im installing a deh-3300ub into my saturn sl1 1999 and i have power but no sound
Did you use a wireing Harness adapter kit to hook it up in your car to the factory radio harness, If not the speaker wires are probally cross up. End thats why your not getting sound,
Dec 06, 2012 | Pioneer DEH-3300UB Radio-CD-MP3-Digital...
Installing an aftermarket radio in a 2001 montero sport, and can not get power to the radio. The only piece not plugged in from the old wiring is the small black plug (it looks like an "S" cable...
That almost sounds like it had a stock amplifier. Did you purchase the correct wiring harness? If you ordered one for your vehicle and didn't specify that it had an amp, it won't take that into consideration, and thus no way to plug it in. Check www.crutchfield.com to see if a harness is availble for your vehicle. Hope this helps.
Aug 23, 2011 | Car Audio & Video
How do i connect Pioneer DEH-P4700MP at home
If you are looking to connect this radio at home, you will first need some kind of 12V DC power supply with an operating range anywhere between 9-16V. You can purchase these online or at most electronics retailers (Radio Shack, Fry's Electronics, etc.). Simply connect the constant memory power wire (yellow) and switched accessory power wire (red) from the Pioneer's wiring harness to the "+" terminal on the power supply and the ground (black) wire of the Pioneer to the "-" terminal on the power supply. Make sure to have at least one speaker connected to the speaker output leads of the Pioneer for sound. The speaker connections are as follows: Front Left + (white) FL - (white/black stripe), F Right + (gray) FR - (gray/black), Rear L + (green) RL - (green/black) RR + (violet) RR - (violet/black). And that's it! Sound at home with your Pioneer radio!
I hope this information was helpful.
Aug 18, 2011 | Pioneer DEH-P4700MP CD Player
Installing DEH-P3700MP in mitsubishi diamante need wiring diagram
The following may help you. The first is for the vehicle the second for the stereo. Good Luck.
Battery WHITE/YELLOW (+) RADIO HARNESS Accesory WHITE/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination RED/BLACK (+) RADIO HARNESS Dimmer RED (-) RADIO HARNESS Power Antenna YELLOW/WHITE (+) RADIO HARNESS Amp Turn On YELLOW/WHITE (+) RADIO HARNESS LF Speaker (+) WHITE LF Speaker (-) ORANGE RF Speaker (+) YELLOW RF Speaker (-) BROWN LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) BLACK Amp Location MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK Steering Cntrls YES THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTARĀ® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT. Speed Cntrl NO Radio Security YES Securityiadame_18.jpg
May 14, 2011 | Pioneer DEH-P3700MP CD Player
The battery for my Kia Optima (2004) recently died. After that my rear speakers will not work. I've messed with the PIoneer (DEH-3200UB) stereo system audio options. All the fade and balance does is affect...
Obviously there's short somewhere or radio have short out. You can change the radio one from junk yard or test each speaker individually @ where the connect to the radio. Want to go even more advance. Get a mutlimeter and check it resistance or etc. If it's the radio that's faulty try unplugging it and plug. The purpose of fade is to fade and distribute the the sound in speakers there for won't help with the problem. You can even use a aa battery to check speaker. If speaker faulty get one out the junkyard.
Dec 29, 2010 | 2004 Kia Optima
02 bonneville. Stock radio has power, but i install my pioneer and no power. I did use a wire harness.
With the stock radio installed, turn on your parking lights and listen for the chime (same sound for key in ignition with ignition off and door opened). Does the sound come from the front left speaker or from behind the dash? If it comes from behind the dash, disconnect factory stereo and turn lights on again, id the chime still there or does it go away? If the sound comes from the left front speaker or goes away when you unplug the factory stereo, you need a different harness, its called a chime harness Pac Audio part #C2R-GM32R, could be the thing you need.
Mar 01, 2010 | Car Audio & Video
Pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Pioneer DEH-P3600 CD Player
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
No sound from speakers
did you check to make sure your vehicle didnt come with a factory amp, if it has one is it turning on? or did you remember to disconnect the negative battery cable while installing your radio, i know thats a dumb question, once i was installing a pioneer a barely crossed a couple wires and fried the radio, the radio itself worked fine and all the features etc, but it never did play sound again. i always disconnect the power now!!
Dec 26, 2008 | Pioneer DEH-P4000UB CD Player
Pioneer DEH3200UB w USB Input  iPod control Car CD MP3 Player Logo
198 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
