Question about Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Clear Crispers, 2 Sliding Wire She...
I have a top mount frost proof 18.2 cu ft Frigidaire (P/N 241691317)and have issues with the freezer. It blows cool air but not enough to freeze food. I do see some ice build up inside the fridge and on one of the aluminium tubes that runs to fan. It used to click in and actually hear a louders sound when the freezer cicked in but havent heard that sound in a while. Tx for any help you can offer.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
if you have a lite frost build up and not large amounts of ice, on your freezer coils, you may have low freon, in your unit..if you have the large amount of Ice, you may have a defrost issue.
The only thing you can do, to help correct the problems. is clean all outside coils, below or on the back of the fridge. vacuum and compressed air to clean them. and see if that helps the issue.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
The refrigerator is not freezing
Hello Teresa, this is JK. I understand that the freezer is not cooling properly. Is the compressor running? Is there air movement through the grille at the rear of the freezer? Is there warm or cold air coming from the louvers? Can you remember any odd functions prior to this issue? If you can think of anything in particular, please feel free to reconnect and maybe it's something I can help troubleshoot. Best regards,
Mar 15, 2014 | Frigidaire Professional Top Mount...
20 cu ft freezer top 1 foot things don't freeze completely. Bottom 1 ft things don't freeze completely. But the middle 18 cu ft its frozen.
Gas is low, also check for air flow obstruction, this may fix it,,also seals at the base of the door....Russ
Aug 22, 2011 | Frigidaire Freezers
Model ET8FTE*V*O* Dampness in the freezer compartment.
the frost free system works by blowing dry air into the cavity, replacing the damp air,some of which has turned to frost on the shiney plastic packaging,when freezing.
it is not unusual, at all, in humid areas it is bad enough to warrant a drip tray.
PLEASE turn off any electric item before sticking your fingers in the holes........
May 20, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire White 16.5 cu. ft. Top Freezer Refrigerator (FRT17HB3)- The freezer works, the refridge portion is warm, it started last week ans seemed intermitten, we turned the cooling higher and it was fine...
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Apr 18, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
The sides of my freezer are very hot while the top, front and back are cool to the touch. The freezer still is freezing items fine.
In the newer freezers and refrigerators they are mounting the condenser coil in the side panels of the freezer or refrigerator eliminating the large usually black frame work of tubing that used to be mounted on the back. This saves room but causes the sides to be warm as the heat is now dissipated by the side panels. You should have about an inch of clearance on both sides to let air flow over the side panels to cool them. I have a newer side by side and it also is feels quite warm when you put your hand on the side.
Oct 07, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Open Questions:
See all Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top Mount Questions
Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Clear Crispers, 2 Sliding Wire She... Logo
802 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
