Question about Acer Aspire One Netbook 8.9" Notebook
How are the processors and ram similar in acer computrs?
  • Acer Master
  • 6,771 Answers
The processor controls the delegation of programs, where the ram controls how fast it is processed.
Posted on Jan 04, 2011
I neeed a USER Manual for ACER MB.SE109.002 Aspire Desktop Board Motherboard
I believe what you are asking for, is a Motherboard Manual, for the motherboard used in an Acer Aspire M5400 desktop computer,
Not available.
The motherboard is made FOR Acer, by a motherboard manufacturer.
In this case the manufacturer does not supply information.
Acer does.
Motherboard,
http://www.shopping.com/acer-acer-mb-se109-002-aspire-desktop-board-motherboard/info
Specifications,
http://support.acer.com/acerpanam/desktop/2010/acer/Aspire/AspireM5400/AspireM5400sp2.shtml
With the above information you can see;
1) Processor Support.
2) Uses a Socket AM3 processor socket,
http://en.wikipedia.org/wiki/Socket_AM3
[ Look at the list of AMD Phenom II, and Athlon II, processors.
Now look at this chart, {Scroll down},
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#Phenom_II_series
Now look at the processor socket used for these processors. Scroll the page down, compare using the charts ]
3) The motherboard chipset is an AMD 880G,
http://en.wikipedia.org/wiki/List_of_AMD_chipsets#A-Link_Express_III
Here you see more information on what the motherboard supports.
4) The Ram Memory used is DDR3 Sdram, at either 1066MegaHertz, or 1333MHz.
(That is PC3-8500, and PC3-10600, respectively)
The Maximum TOTAL Amount for the motherboard is 8GB.
There are 4 Ram Memory slots.
The Maximum Amount for EACH one is 2GB.
NOTE*
O/S = Operating System.
Windows XP, and Windows 7, are two examples of an O/S.
With a 32-bit O/S, the maximum amount of Ram Memory that will be recognized, is 3-1/2 GigaByte. (3.5GB)
You have to have a 64-bit O/S for above 3.5 GB.
(8GB? You need a 64-bit O/S)
ALSO, don't just use any Ol' DDR3 ram memory.
I doubt you can go into BIOS Setup, and change the Voltage, and ram timings, for a high-performance ram memory.
In otherwords 'gamer' ram memory.
JEDEC sets a standard for Ram Memory.
One of the standards is the Voltage. Standard default voltage set for your motherboard by JEDEC, for the Ram Memory, is 1.5 Volts. (DC)
MAXIMUM voltage is 1.575
That Acer board is not capable of handling DDR3 high-performance ram memory, that will exceed 1.5 volts.
(Probably isn't a BIOS upgrade either)
What is it that you seek? Post back in a Comment.
Regards,
joecoolvette
JEDEC,
http://en.wikipedia.org/wiki/JEDEC
May 19, 2012 | Computers & Internet
HP OR ACER IS GOOD BRANDED FOR A LAPTOP?
Hi, HP and Acer are both pretty good branded laptops, better than cheap models outthere like Gateway, etc.
But its not really the brand to look for, its whats inside the laptop that counts.
The processor (intel, Vision AMD) etc
The ram (4gb or above)
The HDD (320gb or above)
the hgher the Ram, and the higher the HDD, the better the laptop.
Also I personally recommend Intel processors as Vision AMD processors can be slow (depending on which type of AMD)
Hope this answers your query
Mar 08, 2012 | Computers & Internet
How are processors and RAM similar?
this may be quite late, but if it helps, you may think of the processor as the brain and RAM as the memory. The brain processes work with the help of thinks stored in the memory. For example, if you see a picture of an animal, the brain will go through the stored information in the memory to identify what animal it is. hope this makes sense. :)
cheers
rodietom
Jan 08, 2012 | Acer Computers & Internet
Shuts down after 30 seconds
1st step: take out the ram and clean it with an eraser..... blow air over the ram slots and reinsert... it shall work 80% chance.
if that doesn't help then:
your PC might have a cooling problem.....
1 change the position of your PC... a place with high air moisture and high temperature can cause similar problems.
2 check , if your fan is working properly.
3 check the Processor IC thermal compound... a paste which is applied in between the processor and the fan.
Feb 16, 2011 | Acer Aspire T310 PC Desktop
Big city rigs
first check if your computer answers the following requirements:
Windows® XP/Vista
Minimum Requirements:
  • Pentium® 1.7 GHz or similar processor
  • 512 MB RAM
  • DirectX® Compatible Video Card
  • 128 MB Video RAM
  • DirectX® 9.0c
  • 2 GB Hard Drive Space
  • Mouse
Recommended Requirements:
  • Pentium® IV 2 GHz or similar processor
  • 512 MB RAM
  • 3D Video Card with at least 256 MB Video RAM
  • DirectX® 9.0c
  • Mouse
if you do, please tell me exactly what happens when you try to install the game
Jan 25, 2010 | ValuSoft 18 Wheels of Steel: American Long...
My Acer Aspire One netbook worked for a yr and now it locks up soon after turning it on & loading windows and eventually starts a continuous beep. I have reloaded the software back to default settings...
hi, if it was the processor you won't get any beep sound and i don't think the laptop would even load windows as you said it is a ram problem open the laptop and try to change the ram of dimm or get a new ram .
Jan 17, 2010 | Acer Aspire One PC Notebook
Does Pentium 4 541 HT support an x86-64(64-bit) OS
An HT processor is not fully capable of supporting the 64 bit OS in the same way that a dual processor is.
Acer is a low to mid price brand but having said that they do usually perform quite well.
Extra ram will be of great benefit to any computer.
Sep 06, 2009 | Acer Computers & Internet
Laptops
I have an Acer Extensa 5620 Laptop and it is Very fast, 3 gigs RAM expandable to 4, 358 MB of Video RAM, Dual Core processor, 1.82 Ghz. I do lots of graphic intensive multi-tasking, the computer keeps pace just fine.
Apr 12, 2009 | Dell Dimension 3100 PC Desktop
Booting problem
Similar problem
started a few days back
Aug 11, 2008 | Acer Aspire 1690 Notebook
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Acer Aspire One Netbook 8.9" Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
