Question about Bissell 8975 CleanView Bagless Upright Vacuum
Tools have no suction - how do I troubleshoot
  • 520 Answers
Start by cleaning all the filters. no suction is usually a filter problem
Posted on Jan 04, 2011
How to clean suction area
If you are referring to the front nozzle area, Hoover has made a tool called a nozzle cleanout tool # 39514003
Sep 13, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
My attachments tool has no suction. I made sure I have selected tools and I cleaned the lint filter. There is definitely suction in the machine, but it does not come through the attachments hose.
Check the attachment hose for any hindrances like clogged with dirt or object. Also a big hole cracks in hoses will cause suction to divert it outside. Clean the machine to make sure it will provide suction powerfully. Regularly clean it and you will assure it's will perform better.
Thanks for asking.
Jul 17, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Is there a switch to turn-off the tools so that
On the Hoover U6311-900 there is no switch that turns off the suction to the tool hose. That hose is attached to the head of the vacuum on the side via a spring loaded "door". Just twist the hose to remove it, the door will close and you will have full suction again.
Apr 06, 2010 | Hoover U6311-930 Power Drive Bagged...
No suction for upholstery hose
http://www.hoover.com/pdfs/manuals/F5914900.pdf try priming your hose
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
Follow the instructions on pages 14 and
15 for the appropriate cleaning task.
Godbless
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction from upholstery attachment
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
these steps:
cleaner ON.
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Have used my Bissell Powerwash Deluxe 4 or 5 times now no suction
We found that the tool wand was blocked, although only used once. But when that was cleared suction was reinstated. Thanks anyway!!
Jan 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Bissell 8975 CleanView Bagless Upright Vacuum Logo
43 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
