Question about Sole Fitness F63 Treadmill
I am getting an "LS1" error with the words "low
4 Suggested Answers
  • 33 Answers
SOURCE: New F80 treadmill. Belt doesn't move after hitting
hi, check the 12pin communication cable
Posted on Oct 11, 2011
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
ercupa190
  • 12223 Answers
SOURCE: F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
Posted on Apr 13, 2012
Sole F63 Treadmill Incline Error
http://electro-medical.blogspot.com/. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience
Jun 26, 2014 | Sole Fitness F63 Treadmill
Low speed fault
With belt movement check speed sensor. Without belt movement check MCB. If you neglected unit it could be belt and deck if its shutting down during a workout. I have also see a lot of on/ off switches getting old and causing LS errors due to low voltage to MCB
Apr 19, 2014 | RTO Sole F80 Treadmill
Thorens TD190 speed problem
Depends if it is a belt drive or direct drive turntable. Most problems like this on a belt are caused by the belt itself, which will be found by lifting the platter matt up. If you need to replace the belt make a note of how it fits before removing it. You can find the belt by searching first for the make/model number and the word "belt". If that doesn't find it, measure in MM the diameter of the belt. You might also need to measure the thickness. Put that into Google with the words "turntable belt". You don't have to spot on with the measurements. Just get the nearest to yours.
If it's a Direct Drive, then that will be an electrical fault, so it might need the attention of a trained engineer.
Mar 30, 2013 | Thorens TD-190 Turntable
Dear Sir:
Apr 13, 2012 | Sole Fitness Sole F85 Treadmill
Display shows LS1low speed code
hai ,
pls check 12pin communication cable and speed sensor wire also
Dec 13, 2011 | RTO Sole F80 Treadmill
I have a few errors on my dryer. I have a GE Profile Harmony. The first error says "The Blower is not getting up to speed". The second error says "There is a problem with the inlet...
There could be an issue with a drive belt which could cause an rpm (speed) problem, an air flow problem, or a temperature problem.
Aug 28, 2011 | Dryers
MyBook 500G not recognized and no files showing. RE: WD5000H1U-00 The Blue light blinks high-low-high-low-steady on when i power on the drive, there is no information on the drive and the drive now...
usually this happens when the usb controller board inside the external HDD is faulty
if you are lucky this board can be replaced with a similar one then you can get your data back
Jun 21, 2011 | Western Digital My Book Essential...
Sole Fitness F63 Treadmill Logo
618 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
