Question about Acer (5604430611) Power Supply
Laptop will not turn on. Tried new battery and ac adapter.
  • 20 Answers
Try to change the memory , with a new one ,
Posted on Jan 04, 2011
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
When i plug the charger in the orange battery light comes on and the computer turns off
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Sep 29, 2012 | Toshiba Satellite P200D-11R Laptop AC...
I have a HP 6735s Laptop. I have been getting a few of the "Smart AC Power Output" messages, however yesterday after I turned my laptop off and then on again, the laptop wouldn't detect the AC...
bad battery,
you do know that the main batteries are "love to fail"
right,
just about all batteries do that in everything,
even the coin cell,inside can fail in 5years flat.
if power pack is 19vdc with volt meter, good !
the battery is next, yes it runs pc but can be bad.
a bad battery can still have power but overloads the charger chip
it really is an analog world. (reality)
if savvy , always keep a spare battery for moments like this.
Apr 07, 2017 | HP Compaq 6735s Notebook
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
Dell x200, no power at all.
By no power you mean the computer is not turning on right?
If that is the case there are just a few things you can check,
1. Check the adapter if it is working fine the LED on the adapter should be lit on when you plug it in the laptop.
2. Check the port where you plug in the ac adapter.
Make sure that the port in the back of the laptop is not damaged.
3.Check the wirings of the ac adapter.
Make sure there not damage.
4. After the 3 steps and you're sure it's a good adapter try to turn on computer. If not.
The best thing to do is to use another working adapter or if you have another laptop try to use the adapter you're using to that laptop and if it is working
then you have a problem.
5.If it ends up that the ac adapter is working including your battery. Then to fix your problem you'll need to replace the motherboard of that computer.
Hope this helps!
Feb 18, 2010 | Dell Latitude X200 Notebook
The AC indicator light stays on for one second after plugging in the ac adapter. The laptop indicates that the improper adapter is being used. i have used the correct battery adapter and tried two known...
try unplug the battery and direct plug the AC power adapter, see what happen..........
and everything ok, that means your battery has problem.
if the laptop don't even turn on, that means the connector of your laptop (the power connect may have problem, THE IS THE WROSE CASE, YOU NEEED TO REPAIR YOUR LAPTOP)
Dec 29, 2009 | Dell Studio 1737 Laptop
Battery was running out on my Acer mini book, hibernated and turned of, tried to turn it on nothing happened., used ac adaptor....still nothing
take battery out, unplug ac adapter. Wait one minute. leave battery out. Plug in ac adapter and turn on laptop. Once it turns back on. Shut down laptop and put battery back in. Now you should be able to turn laptop on with or without battery.
Nov 08, 2009 | Acer Aspire One AOA150-1635 Notebook
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
