Question about Whirlpool Inglis IP4400 Washer
Does the Inglis ITW4300SQ washer have 1 or 2 speeds? Does it agitate gently in the delicate cycle or alternately agitate hard and soak?
Sea Breeze
  • 4655 Answers
SOURCE: Washer won't cycle through...
The cycle timer may be defective and will need replaced. Hope this was helpful.
Posted on Oct 22, 2007
  • 184 Answers
SOURCE: washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Posted on Apr 10, 2008
  • 240 Answers
SOURCE: INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Posted on Apr 28, 2009
garing
  • 998 Answers
SOURCE: On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Posted on Aug 13, 2009
BIKER T
  • 909 Answers
SOURCE: My new Inglis washer, ITW4300SQ, is filling up
your cold water solonoid has either got a dirty filter or the solonoid needs to be stripped and serviced if the valve is serviceable.
Posted on Sep 17, 2009
Speed not changing in delicate mode fex831cso
The spin cycle is not going to change it is how strong the agitation is
And how hard it soins
Jun 05, 2015 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Explanation of Wash Cycles
Sorry but you only have the one speed on this particular brand. Perm and short are just less time. The best thing to do is always use large water setting and less delicates in the load on a short cycle to compensate for the speed and protect your delicate fabrics.
Jan 27, 2010 | Whirlpool ET8CHEXSQ Dryer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Agitator wont work, quiet hum and smell
Noises
Often something works it's way into the pump and makes a clicking or scraping noise. Another bad spot on this washer is the snubber ring that sits between the base and the drive unit.
1) Whirlpool, Inglis, (some) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1picture2.
(2) Whirlpool, Inglis, (some) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
Apr 03, 2009 | Kenmore Washing Machines
Kenmore washer aggiates slower than when new. is
Usually, there are two agitator modes. A Normal ("Fast") mode, and a delicates ("Slow") mode. Put washer in 'delicates' cycle and see if the agitator slows down even further. If it stays at same speed as in perma press or 'normal' mode, then there is an open in the circuit betwixt the controller dial and the agitator control.
Feb 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Damaging clothes
How long is the gentle cycle?. I prefer to make my own delicate cycle. I let the machine fill, agitate about 1 min. then turn off and let soak about 15 - 20 min. Make the machine pump out and start spin very briefly. stop machine. let fill up again and repeat to rinse. Don't let agitate for more than 3 or 4 min total wash and rinse don't let spin completely.
May 06, 2008 | Frigidaire GLTR1670A Front Load Washer
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Inglis IP4400 Washer Logo
Dan Webster
Dan Webster
Sal De
