Question about JVC RX-517V Receiver
Jvc rx-517v remote will not work. - JVC RX-517V Receiver
Where can buy jvc Rx-r75 remote control and if there any other model that would fix
http://www.jvc.newremotecontrol.com/catalog_item.php?catnum=RM-SR75U&refnum=RX-R75
May 16, 2017 | JVC Audio Players & Recorders
I have a URC-9911B00 Oneforall remote, will it work with a JVC RX-7000V Audio/Visual Control Receiver?
The URC-9911B00 remote probably will work with RX-7000V receiver. Try code 0074. The remote was programmed in 2002 and the receiver was listed for sale Amazon in 1999.
I hope this helps.
Jan 27, 2017 | JVC Televison & Video
JVC rx-668v universal remote code
just try go www.fitness.manualsonline.com or www.remotecodelist.com or memorex.com
if You would not FIX IT. i recomend you to exchange by a NEW Ones, the SYSCON inside from the remote control had been faulty see the diagram.
God bless you
Jul 25, 2012 | Televison & Video
RX5032V code
The only remotes that work correctly with JVC is JVC. Some universals can do a couple of things, but 90 percent of your features will not work.
Apr 18, 2012 | JVC RX-6030V Receiver
On my jvc 517v when you turn the volume up the speakers are crackeling and scratchie and speakers sound terrible.
Is this a NEW problem or has it always been like this? What modes or sources are affected? Generally, crackling, scratchty sound is either overdrive distortion, speakers being pushed too hard, or blown speakers.
What is the exact model. Can't find the manual for "517v".
Feb 09, 2010 | JVC Audio Players & Recorders
Power surges
Does it attempt to startup at all? Do you get any lights or any indication that the unit is trying to start? If not, there should be a small transformer inside that is the standby transformer. It generates the 5V standby voltage. I have seen these go open in the primary since there is a fuse built into the transformer. You may need to replace this transformer. You should be able to get to the primary winding. With the unit unplugged, measure across the primary side with an ohmmeter. You should read a low value. If it reads infinity, the primary is open and you need to replace the transformer.
Dan
Aug 07, 2008 | JVC RX-517V Receiver
69 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
