I have a 42 inch LG plasma tv and when I switch it on, all I get are vertical coloured lines on the screen. What could be the cause of this and can it be mended. The TV is only 3 years old so do not want to just dispose of it. thank you. linda footman
SOURCE: jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Posted on May 04, 2007
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
Siliconchip
  • 52 Answers
SOURCE: LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Posted on Jan 05, 2008
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
HDTV GURU
  • 261 Answers
SOURCE: TINY 42 INCH PLASMA. TURNED
Did you get your set up and running yet? Let me know...Jay
Posted on Feb 18, 2008
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
42" LG plasma
It sounds like a bad panel, which is not what you want to hear. Replacing the panel on a Plasma TV usually costs more than just replacing the TV. However a bad panel causes vertical lines exactly as you describe.
Sep 10, 2007 | Sony PFM-42X1 Plasma TV
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Quite some time ago my 42 inch LG plasma developed thin rainbow lines on the left side - now i have 2 1.5 inch vertical lines dividing my screen into 3 sections. can this be fixed ? and at what cost ?
How old it ur tv,ur plasma bulbs might need be replace.Could be the plasma tube it bad because long times use.But ur plasma screen it self could damage kind radiation not worth repairing.
U alway make deal with the repair man come out for estimate.Cost u like u repair with him.
Make sure ask him come out for no cost some charge $40 come out.
Aug 12, 2009 | LG 42PC3D 42 in. Plasma Television
Vertical lines on screen of my 42" plasma
Capacitors on Y-Axis board beginning to fail.
Soon the bars will be permanent - get the tv fixed before they are burned into the screen.
Repair is under $200USD (mostly labor)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 17, 2009 | LG 42PC3D 42 in. Plasma Television
Verticle lines
You should connect your TV to an Active DtH Connection or a Live TV Cable or even to a working DVD/VCD Player etc. and tune it to the frequency of the same and it should start working. If it doesn't, please contact Service Center.
Jun 18, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Plasma tv has no picture only sound.
IF U HAVE A INTINA U SHOULD PROBLY MOVE IT IF U DO NOT U SHOULD CALL A CABLE COMPONY ABOUT IT TRUST ME
Jan 07, 2008 | Gateway FPD2275W LCD Monitor
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
