Question about Sony Televison & Video
Image on KDL-46V5100 produces vertical lines from text/headline bar.
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 668 Answers
SOURCE: I have sparkled vertical lines of color on my Sony
You probably have a Bad LCD panel or a LCD controller. Either way, you must replace the LCD Panel because they come as one piece.
Hope this helps,
Skyassoc
Posted on Jul 04, 2009
  • 5 Answers
SOURCE: Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Posted on Dec 06, 2010
Sony kdl 46v5100 horizontal lines. Is it tcon board?
The TCON board or the LCD panel is faulty. Can confirm by replacing the tcon board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 31, 2017 | Sony Televison & Video
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Kdl-46v5100 tv now dos'nt recognize hdmi.says no
Try another HDMI cable. I have seen them become defective. If it is not the cable, then try another HDMI device to test the TV.
Without an HDMI cable tester, and a way to measure the output of the HDMI source device the only way to resolve this is with the process of elimination.
Jerry G.
Jan 19, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
HDCP not compliant after hook up
We have hooked up our Sony HD TV Bravia Model KDL-46v5100. when we hook up the DVI connectores the message says not
HDCP not compliant, what does this mean???
Dec 31, 2009 | Sony Televison & Video
Sony bravia kdl 32l4000 - color bars running vertically on screen
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Televison & Video Logo
176 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
