Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Best results i got three L7's 2 ohms dvs and a earthquak phd5000 mono block i am tring to get the deepest and loudest bass as possible i would like to know the best way i should wire it all together for the best results also what kind of box u recomend
    Scholar:
  • 96 Answers
Huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Posted on Jul 26, 2008
What are some best cheapest bass amp under 500$?
'Best' and 'Cheapest' are seldom in the same category, but have a read of these links.
12 Best Subwoofer Amplifiers for Your Car or Truck - BestProducts.com
www.bestproducts.com/cars/parts/g662/subwoofer-amplifiers-for-your-car/
  1. Cached
  2. Similar
Jul 19, 2016 - If you want big bass, choosing the right subwoofer is only half the battle. Be the loudest car on the block with the help of these new mono amplifiers for your car or truck. ... 14 Best Rubber Floor Mats for Your Car or Truck.
Best Car Amplifier 2016 ' Top Rated Auto Amplifiers - CarAudioNow
https://www.caraudionow.com/best-car-amplifiers/
  1. Cached
Looking for the Best Car Amplifier of 2016? ... And if you are going to add a subwoofer, a monoblock amp is an absolute necessity. ..... Two-channel A/B ZRX516.2, 500 watts; Four-channel A/B ZRX616.4, 600 watts; Four-channel ... (PCBs) that can perform under the most rigid and extreme conditions attesting to the brand's ...
Bass Packages Under $500 at Crutchfield.com
www.crutchfield.com > ... > Car Audio, Video & GPS > Car Subwoofers & Boxes
  1. Cached
Under $500 - Shop for Bass Packages with the help of real A/V experts. ... package includes Magna Bass MB212P mono amplifier (250 watts x 1 at 4 ohms) and ...
Can you guys recommend me a combo amp under $500? ' TalkBass.com
https://www.talkbass.com > ... > General Forums [BG] > Amps and Cabs [BG]
  1. Cached
Jan 19, 2012 - Hey guys, I'm currently in middleschool and I need a new amp thats preferably 400-500 watts, but under $500. We currently have a bassist, ...
Need good advice on a sub+amp combo, $500ish budget - Car Audio ...
www.caraudio.com > Forum > Car Audio Discussion > Subwoofers
  1. Cached
  2. Similar
Oct 13, 2012 - 12 posts - ‎1 author I'm new to both the forum and somewhat new to car audio in general so please excuse any ... So i need a great sub and amp to complement them for around $500. ..... other subs for under 200 bucks id rther have over type r
World Record Budget Build w/ Drew Wesley's $500 Car Audio System ...
z? 2:32 https://www.youtube.com/watch?v=NOatL_DzZL0
  1. Similar
Oct 3, 2013 - Uploaded by EXOabigdeal World Record Budget Build w/ Drew Wesley's $500 Car Audio System ' 4 12" VVME Subs & Bass Amps ...
Top 10 Best Car Amplifiers To Buy for 2016 - MyCarNeedsThis
mycarneedsthis.com/todays-best-car-amplifiers/
  1. Cached
Whether you're looking for an amplifier to power your entire cars component speaker ... power outputs come in 3 settings (of 800 watts, 500 wats, and 300 watts ). ... Rockford Fosgate R750-10 Class D 4-Channel Subwoofer Amplifier ... Talk about power when it comes to getting some serious knocking under the trunk.
Oct 30, 2016 | Car Audio & Video
I have the Sony explode 1200 2/1 channel amp and 2 comp series lighting audio 10s 8ohm 900 watt max best way to hook up for loudest bass
You will have to wire subs together for a 4 ohm load. Then bridge amp (1 channel). Look on amp speaker outs to see what leads to use to bridge. Run positive and negative to one speaker then use a jumper wire from that positive and negative to the next speakers positive and negative
Sep 28, 2016 | Sony Car Audio & Video
Need bass nobb for my amp
need a remote and quote fora bass knob remote Alpha series quantum amplifier QA3000D Mono Amp.
Nov 09, 2012 | Quantum Alpha Series Qa3000d 3000w 1 Ohm...
Wiring power house phd2 mono amp to the earthquake 4 ohm speakers.
When i hooked up my bass knob the amp made my subs hum i unhook the rca but still humming unhook bass knob still hummin
Jun 12, 2011 | Earthquake Sound PH-D2 Car Audio Amplifier
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
I have a JL Audio 12 ich subwoofer rated at 8 ohms. also a mono block insignea amplifier at one ohm stable 1-4 ohms. how to i wire it safley? possible?"
Your amp based on what you say would have no problems whatsoever with an 8 ohm load, not even if it actually has dual 4 ohm coils and you wire them in parallel giving a 2 ohm load (don't know your particular sub).
Every good car amp has protection circuits to prevent itself or the speakers from damage from too low loads so it shouldn't be a problem even if you screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
Good luck and don't worry!
May 26, 2009 | Jl Audio 12W0 Car Speaker
I have a 12W7 jl sub with no enclosure or amp.
Hello cdoran93,
Well, "best" and "loudest" are mutually exclusive. You can configure for one or the other, but not both at the same time.
The best (most accurate) bass is produced from a sealed enclosure, while the loudest (highest spl) is produced from a properly tuned ported enclosure. The recommended sealed box volume is 1.375 Cu.Ft. Ported is 1.75 Cu.Ft. For a ported enclosure, you need to decide what frequency to tune it for and then look at the JL specifications to the size of the port.
www.crutchfield.com has both types of enclosures at prices starting around $70.
Hope this helps.
May 11, 2009 | Jl Audio 12W7 Car Subwoofer
Just wondering ..
square port (slot loaded) vented box tuned at 33 - 38 hz is the loudest deepest bass you can get
Nov 18, 2008 | AudioBahn A2801Q Car Audio Amplifier
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
232 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
