Question about Bunn VPR Coffee Maker
Water runs thru very slow. i took it apart and build up in the lines.What to try?
    President:
  • 228 Answers
Try soaking the tubes or lines in vinegar over night, make sure they are submerged. then just rinse with soap and water. good luck!
Posted on Jan 04, 2011
Descale bunn cdbcf15 water tank
Running white vinegar thru the line will never cause damage ......and actually should help remove mineral deposits clogging the line. If you want you can reuse the white vinegar and run it thru several times till it has completely removed mineral deposits. Once it is cleaned using distilled water will prevent build up.
Mar 24, 2014 | Bunn O-Matic 28800-0100 - CDBCF-15...
Ice maker makes hollow cubes and water thru the door runs real slow
If your water line is the right size, then what has probably happened is that you have ice build up in the line. You need to take everything out of your freezer, and check for ice. Blow a hair dryer on the warm setting at the point the line comes into the freezer! I have to do this to mine every once in a while!
Jul 30, 2012 | Maytag Refrigerators
I was given this washer as a back up,the lady told me it is 3 years old.A couple days ago she said she was washing and the fill station would not stop filling.I thought it was from hard water build up.I...
Yes if you have removed the water lines from the rear part of your washer and there was buld up there you would need a new water valve.would not risk the chance of a flood hope i helped:)
May 15, 2009 | Washing Machines
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Slow rinse cycle fill
take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Jan 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Bunn VPR Coffee Maker Logo
232 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
