Question about Whirlpool Duet GHW9150P Front Load Washer
What does error code F33 mean - Whirlpool Duet GHW9150P Front Load Washer
  • 1,772 Answers
  • Sorry to read about your problem, I hope this helps you out.
  • The "F33" error code means that the washer has encountered a system error with the pump drive. The parts should be working fine; it is just the connection that caused the problem.this connection, can be defective,
  • Prevention/Solution
  • Stop the current washing cycle, drain the remaining water and remove any clothes left in the washer. Unplug the Duet and pull out your manual to locate the Central Control Unit. Check the wire connections from the control unit to the washer's pump. Restart a load of laundry and make sure the error message disappears.
  • Warning
  • If you cannot locate the pump or Central Control Unit, contact your washer dealer or service technician for further help. Do not play with or touch any plugs that could permanently damage or make the washer inoperable.
  • I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
    4 Thumbs - Very Helpful
    3 Thumbs - Helpful
    Posted on Jan 04, 2011
    Krazytech
    • 725 Answers
    SOURCE: kenmore elite he4t
    really need the whole model # ?
    1 pressure switch
    2 flowmeter
    3 CCU
    4 hose
    he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
    Posted on May 20, 2008
    • 57 Answers
    SOURCE: F33 error code
    F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
    OR
    If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
    Press PAUSE/CANCEL twice to clear the display.
    Possible Causes / Procedure
    1. Check for crack or holes in the washer tub and pressure switch hose.
    2. Replace components if necessary.
    Posted on Jun 24, 2008
    aborcass
    • 2651 Answers
    SOURCE: whirlpool duet sport. I am getting a f33 error code.
    i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
    Posted on Mar 12, 2009
    vickygomar
    • 460 Answers
    SOURCE: ERROR CODE F33 AND 5D
    5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. F33 MUST be fix by a technition Service ONLY am sorry about this inconvenient. "Was this helpful?"
    Posted on May 11, 2009
    blueextc3221
    • 15935 Answers
    SOURCE: error code f33
    The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
    Please see the following image provided for instructions.
    http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
    Remember to disconnect power to the washer before attempting access.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Posted on Sep 12, 2010
    What does the code F33 mean
    The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit). Remember to disconnect power to the washer before attempting access. could be a bad pump or loose wire connections. good-day !
    Nov 17, 2011 | Kenmore Washing Machines
    Everytime i try to run a load of wash i get a F33 error - what can i do?
    Please clarify the Model and Make of your Washer.
    The F33 error for Whirlpool: The "F33" error code means that the washer has encountered a system error with the pump drive. The parts should be working fine; it is just the connection that caused the problem.
    Check connectors on central control board.
    Mar 09, 2011 | Washing Machines
    What does F33 mean- its the code on my front loader washing machine
    "F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
    Thank you !!
    Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
    I have a Kenmore He2plus washer that gives me an error of F33
    Thank you !!
    Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
    I am getting a S2 and a f33 fault and the washer is not draining what is the problem?
    Hi, "F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
    Apr 10, 2010 | Kenmore HE2 Plus Front Load Washer
    Error code f33 on an he4t
    Oct 11, 2009 | Kenmore Washing Machines
    I have a front load whirlpool washer and it keeps flashing f33 and won't work
    Apr 29, 2009 | Washing Machines
    Whirlpool duet sport. I am getting a f33 error code.
    Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore elite he4t
    1 pressure switch
    2 flowmeter
    3 CCU
    4 hose
    May 20, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite he4t
    May 20, 2008 | Kenmore Elite HE4 Electric Dryer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    466 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
