Question about M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card
Nothing happens when plugged in to my laptop - M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card
    Scholar:
  • 59 Answers
This could be a number of things, lets go over the most likely.
-It is possible if you have an older laptop that you have USB 1.1 ports instead of the needed USB 2.0 port required to provide the device power. (If it has a separate "optional" power supply, use it.) Or all of the USB 2.0 ports are being used. Try unplugging all of your USB devices except for the interface and try it in different ports.
-If this isn't a problem and you have free and powered USB 2.0 ports then the next most likely culprit is bad drivers. Try uninstalling the drivers for the device (if you've installed them) and downloading the newest drivers from the M-Audio web-site and installing those.
Great choice of gear, I use quite a bit of M-Audio equipment myself and it's good quality for a good price...
Hope this helps. Thank you.
Posted on Jan 04, 2011
  • leibroadcast Jan 04, 2011
    i bought the mobilepre about 6 years ago and used it t perfection i recently moved and have not used it for about a year and a half... i plugged it to 3 seperate laptops (brand new laptops with 2.0 ports) and nothing... it doesnt pop up but the light and power in the mobilepre does go on...
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
Battery light flashes and nothing else happens
Yes, the socket broken loose could be your trouble and is common as we are not careful when we insert the plug all the time.
Apr 19, 2012 | Computers & Internet
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Won't turn on
Try taking the battery out and powering it up.
Dec 17, 2009 | Toshiba Satellite M305D Notebook
Nothing happens when you push the power button
i could be static build up . this is common. Try taking the battery out and unplug the power adapter. now with both removed press the power button on the laptop for approx 20 secs. then plug it in and see if it boots up.
Dec 02, 2009 | Compaq Presario 700 470024-192 Notebook
My a4tech g7630 is not recognized on my msi wind u100 notebook, i plug in the receiver and nothing happens, i know the mouse is fine because it works on my other pc, but nothing on my laptop, i haven't had...
Try installing the latest drivers for your mouse. And make sure the mouse is plugged in before booting yoru laptop, sometimes that can cause an issue.
Oct 17, 2009 | Computers & Internet
Acer 3000 Will Not start
From what you've described so far, it appears the motherboard has failed. Additionally you can remove any other components you can easily access such as hard drive, optical drive, memory and any cards. If there is no change with all components removed then it is most likely the motherboard.
Jan 28, 2009 | Acer TravelMate 803LMi Notebook
Laptop
Not uncommon... the power switching chip that regulates standby and other power regulation to the board must be faulty or fried. Must replace motherboard.. Try removing battery.. sometimes batteries will short or try to draw too much power and put the chip on the fritz..
best wishes.
www.techvisitor.com
Oct 29, 2008 | Computers & Internet
Toshiba L20 - screen appears dead?
Try to plug in an external monitor on laptop to check if there is a problem with your LCD.
Plug in the external monitor then boot the computer. If still nothing happens try removing the battery and the adapter, let it rest for a minute then plug in only the adapter and try to boot up with out the battery.
Hope this helps.
Sep 13, 2008 | Toshiba Satellite L20-S310TD Notebook
Open Questions:
See all M-Audio Mobilepre USB Bus-Powered Preamp and Audio Questions
M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card Logo
295 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
cvtrig
Level 1 Expert
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
