Hello, I have a couple of old mercury thermostats that no longer work. I removed them and put a 2 wire connector cap on the wires and tucked into the wall. Is this safe and can I spackle and paint over?
  • 472 Answers
The circuit is 24 volt circuit as long as you have them protected and don't plan on using them you should be o.k. hope this helps please give me a vote
Posted on Jan 04, 2011
Testimonial: "Thanks!"
Eden pure starts blowing hot air and then turns cold
I recently fixed this issue for a family member on this exact model, the same issue, it would heat fine for 15 minutes and then cold blowing air would follow afterwards non stop, and when we powered down the unit and restarted it, it did the same exact thing. ( What worked for me ) was ordering a new " Thermostat " which is a white rectangle looking plastic thing with 2 blue wires coming out of it, you can find You-Tube video's showing you how to remove the Eden-pure gen3 cover housing easily, my total cost of this do it yourself repair was just under $20 as of 10/10/14 your cost could vary depending on different factors.
1st...unplug the unit....duh ! lol
Once the housing is removed, look at the top of the unit and locate the 2 blue wires coming out near the front, remove the 2 top screws holding in the thermostat, gently pull out the old thermostat but don't disconnect any blue wires yet, put the new thermostat in facing the exact same way as the old one, re-tighten the 2 screws, next follow one blue wire ( One is longer than the other ) to its location on the block, determine if its the shorter or longer wire, disconnect just 1 wire with a Phillips screw driver, and replace it with the like sized blue wire from the new thermostat, tighten but not over tight ! next do the same for the next blue wire on block.
After thermostat is secure and wiring is secure, put the cover and panels back together......and plug it in and test it again....... Hope this works for you as it did for me.
Good Luck !
Oct 12, 2012 | EDENPURE MINT A3705 Infrared Remote...
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Need tofind out what a control circuit for a 2003 Grand Marquis fan motor can be located
If your fan went out, check the Resistor for the Blower motor. Just trace back the wires from the fan to a connection on the Firewall. This part will have 2 small bolts and 1 wire connector. Tap that part and see if it will start working.
If you get a Replacement part you can hook it up to the connector before removing the old part. It should work instantly if that is your problem. To remove the old part, you will need to deal with the heater hoses that are in the way.
I had to unhook 1 at the rear of the engine. I worked on a cold engine and I did not lose much Antifreeze by disconnecting the hose. My car was a 2002 Grand Marquis. Guess leaving the Radiator cap on keep the water from pouring out the engine.
Oct 07, 2010 | 2003 Mercury Grand Marquis
Chest freezer not used for many years will not run now. Seized compressor? Can this be "unseized?
May be possible but most likely electrical, turn it on for 1 minute, listen for any clicks, turn it off, feel the compressor, if it is seized it will be warming up, if cold the problem is electrical quite likely the thermostat.
Apr 17, 2010 | Amana ABB1921DE Bottom Freezer...
Tried replacing old thermostat and now heater won't turn on
Make sure you get the t-stat back on the wall exactly as it was. It needs to be level for it to work properly. Then turn off the power to the furnace for a minute or so, then turn it back on. This will reset any faults that may have locked it out.
If this still doesnot work then you may have shorted the wires. Often on old systems the wire coverings are bad and if the bare wires touch any metal or even sometimes each other they can short out the transformer. If the transformer is dead them nothing will work. I'm afraid you may have done this inadvertantly.
Heatman101
Jan 25, 2010 | Heating & Cooling
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
Have dayton model 2e215 mercury thermostat and trying to replace with programmable. How do I get the old one off of the wall. It looks like the mercury vial sits on a cover over the wires but I cant see...
There are either 2 or 3 small screws which hold the thermostat to the wall plate.
Remove these and the thermostat will come off to reveal the wall plate with the wiring connections.
Sep 06, 2009 | Heating & Cooling
Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Mar 29, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Aug 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
