My LG LED TV is stuck on mono , it isn't letting me change it either . everytime i try to go down on the SAP list , there's only one option , and it is mono , how do i get rid of this feature . it isn't letting me watch TV ,
Mine is stuck like i cant do anything the buttons on it and on the remote isnt working idk how to fix this
Posted on Jan 26, 2013
5 Suggested Answers
SOURCE: MONO - SAP
In the audio menu, you should be able to select stereo or turn off sAP -- you may have to unplug the set for about 20 seconds and restore power to reset it, or return it if the problem doesn't go away. If you end up replacing the set, try for a JVC, Panasonic or Toshiba if you can switch. I think they will last longer for you.
Posted on Jan 11, 2007
SOURCE: sylvania LD155SC8
i need remote control
Posted on Apr 12, 2009
landsend
  • 1066 Answers
SOURCE: mono stereo sap on screen
you need to reset the preferences on you sound icon in the menu panel
Posted on Mar 26, 2009
SOURCE: Vizio VF551XVT 55' LCD LED HDTV no sound on HD
I have the same problem. I even returned one of these tvs and the same problem exists.
Posted on Mar 26, 2010
Turn off stereo sap in tv
buy an rca universal remore for 8.00
Oct 14, 2013 | LG Televison & Video
The vocal commentary for blind people has switched itself on. how do we switch it off?
It may depend on the model. Usually this is in the SAP options. It may be adjustable in the Quick Menu. Otherwise, enter the Menu > SAP (if an analog channel). Press Enter and then select SAP, Mono or Stereo and then press Exit.
If you are watching a digital source, then Menu > Multi Audio. Press Enter and then choose the language/content and then press Exit.
This is for the 32LD550. If you have a different TV, try LG's site: http://www.lg.com/us/tv-audio-video/televisions/index.jsp . The manuals are available for many of the TVs.
I hope this helps.
Jan 29, 2011 | LG Televison & Video
There is no sound from the unit. I have no remote but it says it is in sap mode. can I correct this?
SAP means "Separate Audio Program" - usually SAP mode is for changing the language of the broadcast (i.e. from English to Spanish) and is also used to enhance the sound broadcast of some programs.
Not having a remote may make this difficult.... you need to find a way into the set's menu- some sets have a "menu" button on them..... some require two buttons be held down together.... look at the set carefully.... if you have the manual, it is a good time to look at it.
When you get into the menu, find the AUDIO menu and de-select SAP. Your sound should be restored.
If you cannot get into the menu, you will need a remote. Write down the brand and model of your set, go to a decent electronics store, and browse the "universal remotes". Find one that supports your set and follow the instructions to set it up for your television. You will then be able to access the menu and turn off SAP.
Jan 28, 2011 | Televison & Video
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
Audio only has mono how do you change it
If you open the menu,there should be an option for sound.If you have a universal remote,you will probably have to do it with the buttons on the TV.SAP and stereo are about the same.It most likely cycles through mono,stereo,SAP with the volume button.Good luck!
Aug 05, 2010 | Sharp Televison & Video
I am getting SAP or Spanish on some stations. How do I change or remove that feature?
Press the Stereo or MTS button on the remote control until the words STEREO appear on screen. There usually are 3 options MONO/STEREO/SAP
Jun 29, 2010 | Orion STV2763 27" TV
Sound goes off for milliseconds
Try changing some audio options in the menu, look for MPEG, Pro Logic, Dolby. It may be set to Auto
Apr 27, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I cant get SAP off the tv
Access your menu, and navigate through.
Look for the Audio option then something with the words "SAP" or "Secondary Audio Programming"
then, of course, change it to mono or stereo.
With your universal, press the "TV" button or the button you would press to have it communicate with your TV, then press menu or settings.
Dec 12, 2008 | Televison & Video
TV stuck in SAP mode
The link above does not work.
Aug 13, 2008 | Sylvania 6427TE 27" TV
Televison & Video Logo
568 people viewed this question
Top Televison & Video Experts
Electro Med Services...
