Question about Sony PlayStation Portable (PSP) Console
It gives a blurry double image for all the games I play and I play on it making it hard to play and hard to read i tried taking out battery and putting it back in but it didn't work I have had it for only 3 years.
  • 839 Answers
If you are facing problem in PSP then just don't worry...... You can fix it with the help of repair guide......... you can download it and solve your problem easily......
I will give you the link to download... I hope it will solve your problem...
Click here to download PSP repair guide
Posted on Jan 04, 2011
I would like to buy PSP game,but i dont know how many models of PSP game(Ex : PSP 1000/2000/3000).May u tell me clearly about them?
psp 1000 (also known as the fat) are the original model that they came out with.
psp 2000 (also know as the slim) are the 2nd generation of the psp.
psp 3000 (also known as the new slim) are the 3rd generation of the psp.
depending on who you talk to or read some people say that the psp 2000 were the best of the models. psp 3000 have improvements over the 1000s n the 2000s in grfx but if you play a lot of games that are like the older classic games that are heavy on sprites the image looks doubled and blurry. but if you play new games like god of war and such you won't have that problem with the 3000 models. so i guess it depends on what type of games you play the most on it.
if you can... i say to wait till this holiday season when sony will release the vita. it is their next handheld machines and it looks incredible.
Aug 25, 2011 | Sony Video Game Consoles & Games
Tip
BURNING X-BOX & GAMECUBE GAMES USING CDRWIN...
1) Insert your original in your CD-ROM.
2) Open CDRWin (or any other image extractor) to make an iso image of the game
on your hard disc. Click on 'Extract Disc/Tracks/Sectors'
3) Here are the settings which work for me (!):
Disc Image/Cue sheet
File-Format: Automatic
Reading-Options:
RAW, CD+G, CD-TEXT and MCN/USRC all Unchecked
Error Recovery: Ignore
Jitter Correction: Auto
Subcode Analyses: Fixed
Data-Speed: MAX
Read Retry Count: 10
Audio Speed: MAX
Subcode Threshold: 900
There are a lot of reports, that Raw reading also works, but I had problems with it enabled.
4) Click on 'Start'
RECORDING TO A DISC
1) Install Fireburner
2) Double click on the Cue File For The Game
3) Right Click And select burn To CD
That?s all there is record DAO, and you can try to burn it fast at 2X
Using PNY Black Diamond CDR'
on Mar 19, 2010 | Computers & Internet
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
While working on my laptop it suddenly become blurry, the images are seems mirrored, the text become doubled and it hard to read. The graphics display was really blurry and even i open to safe mode still...
Look for a 9 pin or 15 pin plug on the side of your laptop. You can connect an external monitor to these type of jacks . If the display on the external monitor is clear then your laptop display panel is the culprit.
Jan 05, 2011 | Computers & Internet
Image on Monitor is slightly blurry
Try reducing the screen resolution to 1/2 of what it is now!
Jan 20, 2010 | Acer AL1916W 19" LCD Monitor
Tip
Copy XBOX Games
Burning X-BOX & GAMECUBE GAMES using CDRWIN
2) Open CDRWin (or any other image extractor) to make an ISO image of the game on your hard disc. Click on 'Extract Disc/Tracks/Sectors'.
Reading-options:
RAW, CD+G, CD-TEXT and MCN/USRC all unchecked
Data-Speed: MAX
Audio Speed: MAX
4) Click on 'Start'
RECORDING TO A DISC
2) Double Click on the Cue File for the Game.
3) Right Click and select burn to CD.
That's all there is record DAO, and you can try to burn it fast at 2x using PNY Black Diamond CDR'.
on Jan 20, 2010 | Computers & Internet
Tip
"BURN" YOUR FAVORITE "XBOX GAMES"
BURNING X-BOX & GAMECUBE GAMES USEING CDRWIN
Reading-Options:
Data-Speed: MAX
Audio Speed: MAX
4) Click on 'Start'
RECORDING TO A DISC
on Jan 03, 2010 | Computers & Internet
I have just got this 22'lcd Samsung 225ms. I cannot seam to fix the problem of blurry letters. This can be very hard to read even at a distance. I have searched for updates online for my nvidia g force...
This monitor will only have a sharp image at a resolution of 1680 x 1050. Any lower setting will result in blurry images.
In an LCD the pixels are fixed, and using any resolution lower than the optimal will cause blurry images. This is called Image Scaling:
http://en.wikipedia.org/wiki/Image_scaling
If that resolution causes the icons to be too small, you can change the DPI setting to 120 from 96, that will make them larger
Jun 09, 2008 | Computers & Internet
Double printing
This one is too lenghty to give you here, goto lexmark.com, and in support knowledge base, search with this line...blurry, fuzzy, or double print from a lexmark x4720...There is specific info on test pages you need to run to narrow this down.
It could even be a conflict with motherboard/proccessor that can occur with some e-machines, compacs and others using certain amd chipsets
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
My printer prints blurry lines!
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge.  if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
Good Luck.
Oct 31, 2007 | Office Equipment & Supplies
Sony PlayStation Portable (PSP) Console Logo
148 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
