Question about Estate TEDS840JQ Electric Dryer
I bought a used Estate whirlpool dryer and dont have the power cord connection instructions. Has a black, red and white, and green wire. the green is suppose to be the ground wire. Where does it go?
  • Estate Master
  • 7,482 Answers
Go to this website to see how to connect your dryer cord
Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Posted on Jan 04, 2011
  • 1 more comment
  • nklecz1980 Sep 24, 2011
    I also have a similar problem. However, the Estate model has a GREEN wire connected to the frame. I read another instruction guide where they show a WHITE wire for the same model connected to the same location. In this set of instructions, the white is connected to the center port, and then the new white from the new wire is connected on top. The new green is connected to the body. However, another instruction guide states that "if you have a green wire connected to the body, you can leave it there and simply connect the green from the 4 prong wire to it. Very confusing....
  • Aaron Thomas Searcy
    Aaron Thomas Searcy Dec 09, 2013
    MOTOR STOPPED RUNNING
    FAULTY GROUND? FUSE?WHICH ONES? HEATING ELEMENT STILL COMES ON.
Bought a whirlpool dryer used and the power cord isnt connected how do i know how to connect it
Hello
Here ya gooldtech2332.jpgoldtech2332_0.jpg 3 wire cord center to center outside to outside 4 wire red to red white to white black to black and green onto the cabinet
Aug 13, 2011 | Whirlpool Dryers
We were given a HOT POINT Heavy Duty Dryer with Automatic Dry Control, Model DLB2650BRLWH, Serial No. DG241274H and had to buy the power cord to go with it. Ordered the cord from a local appliance company,...
Technical explanation: Older 240 Volt appliances use a three-wire power cord (Black, White, Red). The White wire is the "neutral" connection, which is tied to Ground at the service entrance panel. The Black and Red wires are opposite phases of the 240 VAC (when one goes positive, the other goes negative). The neutral wire is "in between", so measuring the voltage between the black or red wire and neutral would give you 120 VAC. The green wire is frame ground; the electrical code requires newer (since 2008) 240 VAC appliances to have a separate ground bonding connection to the frame; the neutral connection is not considered adequate protection for certain failure conditions.
Look for a screw head or terminal stud on the frame or sheet metal of the dryer labeled "Ground", "Earth", or one of the following ground symbols:
The green wire goes to this point. DO NOT connect the green wire to any of the wiring inside the dryer, unless it is a green wire attached to sheet metal or a bracket!
The black, white and red wires go to black, white and red terminals you already found.
Mar 17, 2011 | Hotpoint Dryers
If you are installing a new power cord on a whirlpool dryer and you have a power cord with one green wire one black wire one white wire and one red wire where do you connect the wires when the terminals on...
Good day,
The green is screwed to any convenient place on the cabinet. It's a safety ground wire.
The white goes in the middle of the block. The red and black go on either end. Doesn't matter which.
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
After conversion from 3 prong to 4 prong dryer wont work
YOUR FOUR WIRE CORD IS AS FOLLOWS RED,BLACK WHITE AND GREEN ON YOUR DRYER YOU HAVE FROM LEFT TO RIGHT 123 CONNECTIONS THE TWO OUTERMOST(1 AND 3) ARE HOT LEADS SO HOOK RED TO 1 AND BLACK TO 3 NOW HOOK WHITE TO 2 AND THE GREEN CAN BE ON THE TERMINAL COVER SCREW OR NOT AT ALL BUT BE SURE IT CANNOT COME INTO CONTACT WITH RED OR BLACK
Apr 27, 2009 | Estate TEDX640JQ Electric Dryer
Converting from 3 prong to 4 prong
red and black go to the outer sides. white always goes in the middle and green just screws into the cabinet. so I would connect black to black white toi white and the blue to red and green to the cabinet
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
4 CORD WIRING ON ESTATE DRYER M#EED4400VQ0
red and black go to either end, white in the middle, the green gets placed to teh ground strap just off the terminal block itself
Nov 06, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Putting new power cord on dryer i have a 3 cord set up a red wire a black wire and a white wire and dont know which wire to connect to which.
on the back of your dryer.
1.connect the white wire to the center of the junction box.
2.than take the red wire and connect it to the left side of your junction box.
3.than take the black wire and connect it to the right side of the junction box.
If you have a green wire on the cord as well. PLEASE make sure it is connected to the dryers back panel. do not leave it to hang.
Please do not forget to rate and comment about your experience today.
Aug 16, 2008 | Whirlpool Dryers
Estate TEDS840JQ Electric Dryer Logo
80 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
