Question about Ovens
I have a Samsung Range Model number FE-R500WX soup was spilled on the cooktop and has run down the front of the unit and in between the glass of the front door. this unit offers no solution for removing the front glass to clean in between unlike other appliances i have owned in the past do i have to break out the screw drivers to get the front glass off or is there an easier way
ranger25
  • 72 Answers
SOURCE: glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Posted on Jan 27, 2008
SOURCE: nef u1461 top oven
hi managed to clean my oven door this week end! yes you undo the two screws nearest the middle - but you will need an alan key to undo the top glass pops off -there is a spring clasp underneath - just ensure that you leave the door flat whilst you taking it apart. hope this helps i now have a nice clean oven door - you will be able to clean all parts once you pop off the glass - hope i was usefull!
Posted on Jun 03, 2008
AlmostBob
  • 550 Answers
SOURCE: Frigidaire Dble OVen Model FEB30T6DCC Stainless (electric
This exploded diagram of the door should help you get it apart, 4eb927f.gif It is going to be shrunk by the forum software, the full size image is
here http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=FEB30T6DCC&mfgModelNum=&fkMfgID=4
along with a full list of parts should you need them
Posted on Sep 23, 2008
  • 107 Answers
SOURCE: Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Posted on Mar 25, 2009
  • 49 Answers
SOURCE: I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Posted on Oct 10, 2009
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
We have a kitchenaid superba oven glas top and i like to clean it but i do not know how can you help me e-mail me at
Purchase a cleaning spray. Easy-Off Glass Cleaner, Windex or Drackett Glass Cleaner are all available from local department or grocery stores. You could also use dishwashing soap. Any non-abrasive, bacteria or grease removal product would clean glass cooktops.
Spray the whole cooktop area. Allow the cleaner to sit for about 2 minutes. If you have stuck-on food, spray only that portion of the cooktop. Let the liquid sit for approximately 5 to 10 minutes.
Use hot water. Soak your sponge and wring it out. Wipe down the glass cooktop. Carefully scrub the stuck-on food. Run the sponge over the spot area at least 20 times to remove the food. Wring out the sponge and rub the remaining portion of the glass countertop
Use a terry cloth rag to wipe down the cooktop. This will remove excess water and soap.
if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Jan 01, 2011 | KitchenAid KEBS177 Electric Single Oven
Cannot find the model number of my oven and really need an inner glass seal. the model number is not in the manuel! help!!!!
look just inside oven door just below the cooktop/or look on top and just behind the rear control panel,or on back panel,or in lower pull out drawer of unit its one of those places
Sep 30, 2009 | Ovens
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Mar 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I don't know where to look for a Glass Cooktop Replacement
What is your model number and I can look up the part and tell you what they cost so you can call some appliance stores for comparison
Jan 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Sep 23, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Glass window cleaning!
Jan 27, 2008 | Ovens
Glass for stove
You need the full model # off the range not the owners manual
Jan 09, 2008 | Ovens
Ovens Logo
148 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
