Question about Air Tools & Compressors
Air pressure only builds up to 45 lbs. compressor continues to run. I drained all the air and it still only builds up to 45 lbs.
  • 6,826 Answers
The check valve is not holding the pressure back off the head,therefore allowing the pressure to build up fully.
Posted on Jan 04, 2011
Salon tc 60 airbrush compressor won't build up over 17 lbs pressure.
Either the pressure switch needs adjusted or the compressor needs rebuilt.
Jul 27, 2012 | Hobbypet TC60 Super Quiet High Performance...
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
Craftsman pro mod# 919167770 , oilless air
Check to be sure your drain valve under the tank is turned completely off first
Mar 12, 2010 | Air Tools & Compressors
I Have a 5.5.hp oilfree air compressor that builds air up to 45 lbs an stops building pressure and keeps run.will not shut off
Is you air regulator working? I suspect your reed valves in the head need replacing as they may not be holding pressure over the 45psi that you mentioned, and are allowing the air pressure to defeat them which allows the psi over 45 psi to bleed back into the air compressor cylinder.
Oct 29, 2009 | Air Tools & Compressors
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Unit turns on, builds prssure to about 45 psi, and won't go any higher. Continues to run. regulator is set for max line pressure.
Compressor has a bad valve. Needs to be replaced. The owners manual should have a break down of the compressor. Order the head kit.
Aug 05, 2009 | Campbell Hausfeld 02-Gallon Air...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
287 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
