Tevion lcd 3207 tv, sky remote control code please
  • Anonymous May 10, 2009
    no code for sky plus remote
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Posted on Apr 26, 2009
Where can we I obtain Codes for Tevion 32 LCD TV,? since I am unable to receive Sky programs!
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jan 24, 2016 | Tevion Televison & Video
Sky remote code for tevion tv model 43858
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
Oct 16, 2012 | Tevion Televison & Video
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
Tevion LCD3210ID remote codes - Please Help
i cant get anything on my tevion television/dvd
May 22, 2009 | Televison & Video
Sky remote control code
Hi!
Sky Digibox
Thanks
Rylee
Apr 26, 2009 | Televison & Video
Remote control code Tevion TV
Goto. www.medion.co.uk - pick support, enter model number 83388 and you'll get access to the manual
Nov 24, 2008 | GE JASRM84964 Remote Control
Code to progarmme Tevion TV
Might be a bit late - but I hope this helps..
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Jul 22, 2008 | Televison & Video
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Omega urc-08 device codes
Original link no longer working. Found this: http://files.remotecentral.com/download/220/urc08-manual.zip.html
Comment if it's wrong one.
Nov 22, 2007 | Televison & Video
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
Electro Med Services...
