Question about Hobart A200 Stand Mixer
I bought a used Hobart A200 20 quart stand mixer that hesitates or 'gets stuck' when mixing dough or other thick (hard to mix) material. When running without a load, or only a light load it doesn't stick at all, but first gear seems a little fast. I've uploaded a video of this to youtube which might help describe the issue. It can be seen at: http://www.youtube.com/watch?v=PHIm0my57-8 Thank you for any help you can provide.
  • emsmith2323 Mar 09, 2011
    aadzut - Thank you for the information. Our 6 month old restaurant has been keeping us pretty busy so I haven't had a chance to respond. We've been making due with the mixer by mixing very small quantities (about 2.5 lbs) of light bread dough. I was able to locate an A200 user manual, which lists the maximum light bread capacity as 25lbs, and heavy bread dough as 15lbs.
    Our standard batch of light bread dough is 10lbs and causes the mixer to stall in any gear. During both normal operation and when stalled it is fairly quiet (just the expected 'whir') and it stays reasonably cool. No grinding sounds, no odors.
    I'm familiar with electronics repair and would be capable of testing the motor if anyone has the specs or could point me in the right direction. Any info on where/how to obtain schematics, troubleshooting procedures, etc would be helpful. I haven't been able to find much on my own unfortunately.
    Also, could this be related to an issue with the power supply or other electronics supporting the motor...or maybe if it is actually a 220v unit mismatched with a 110v housing (e.g. from a prior repair)? It is old and we don't know the history so anything is possible.
    Scholar:
  • 44 Answers
First of all, I want to say that it is common for people to overload the A200 mixer when mixing dough. The owner's manual gives an extensive chart for various substances typical of what people may mix. Depending on the consistency of the dough, the maximum batch size varies, but as an example: 9 lbs. max with 40% absorption ratio thin pizza dough, 1st gear only, 5 minutes maximum mix time. I remember this particular batch size/specification because as a technician who works on these mixers frequently, I had a customer attempting to mix 20+ lbs. of that 40% pizza dough for much more than 5 minutes and didn't understand why the mixer would stall and why his mixer was so hot he could nearly cook eggs on it's transmission case. So, a word of caution (9 lbs. at 40% A.R. is approx. 7 lbs. flour, plus the water) about overloading these. If used to mix reasonable batches, they are excellent mixers and will last a lifetime (I regularly service 40-50 year old A200 model mixers that run very well).
If you don't hear any grinding when it's stalled (which would indicated stripped gears, damaged keys, etc. in the transmission) I would say you are overloading it. Many people want to say the motor is weak when the mixer stalls, but unless the motor has been repeatedly and severely overheated to the point of shorting some of the motor's windings, that's not the case. I suggest finding the recommended capacity chart from Hobart and abiding by it and you'll love your new mixer for years.
Posted on Jan 10, 2011
Testimonial: "Great advice and suggestions for next steps. Thank you!"
  • None Mar 09, 2011
    To narrow down if the problem is in the motor, do the following:
    Remove the two screws on the top of the mixer and remove the cover they hold on (caution - one of these screws, I don't remember which, has a nut attached inside the top cover to assist in lifting the cover off. If you attempt to remove this screw first, it will turn a few turns and feel stuck. At that point remove the other screw first to avoid damaging the top cover).
    With the cover off, you can see the motor's cooling fan blade. Run the mixer with a load heavy enough to make it stall. If the motor is indeed stalling (visible by noticing the fan blade stopping along with the dough hook), then you can rule out transmission troubles for the time being.
    The oldest A200 mixers used motors with carbon brushes which wear out, but the brushes are only used to start the motor. Once the motor starts, they aren't doing anything (I may be wrong about that, they may be creating a current path for rotor current after the motor is started). To see the brushes, remove the two side covers at the rear of the motor/transmission housing. You'll see two spring-loaded arms pressing down on black carbon brushes. Most importantly, the arms should not be bottoming-out on the casting which holds the brushes - the spring-loaded arms must maintain pressure on the brushes, pressing them into the commutator.
    At this point, rather than drone on even more about all the posibilities, I'll wait to hear back from you as to whether or not the motor is stalling when the dough hook stops.
I have a Hobart A-200 that no longer will mix a 5lb bag of flour to make dough. The hook after a while just bogs down and the motor continues to run smoothly. When we first bought the machine it easily...
I don't know how long you've owned this mixer, but these motors do wear down over time. They don't last nearly as long as the ones made decades ago, the plain basic workhorse mixers with no frills.
Have you tried mixing smaller amounts to see if that works better? Unfortunately with the high cost of servicing, you may find that repair will exceed more than half the value of the unit... leaving the purchase of a new one as your most economical choice.
Sep 22, 2013 | Hobart A200 Stand Mixer
What can you use for a hobart h600
The Hobart H600 is a 2 horse power, 60 quart mixer, it can be used for many things in the kitchen. It can be used to make about any kind of food that needs mixed, wiped or kneaded. It works well in a pizzeria for all facets of making pizza from the dough, to shredding the cheese with an attachment, to a restaurant that makes mashed potatoes and fresh bread, to a full service bakery.
However, the biggest thing that you need to know is the capacity of the machine. As overloading the machine can cause damage that may be costly and take a technician to fix. I do not know what attachments you currently have so I will go over a few of them.
The main attachments are a Wire whip, Flat beater, and Dough hook. There are three different types a "D" wire whip (has many wires and is evenly spaced) this is used to whip egg whites, whipping whip cream, etc. The "C Wing" (has six tines in it) is used for items that are heavy for the D wire whip, like whipping potatoes or icing. The last is the "I" whip is similar to the D wire whip just with less tines. The flat beater is used to mashing or mixing examples are mashed potatoes before they are whipped, cake mixes that do not require whipping, batters and icing. The Dough hook is used for kneading dough examples are pizza dough, bread dough, etc.
The biggest thing when using your mixer is to know its capacity for the material that you are mixing. All though this is one of the bigger machines it still has limits. You should refer to this the following link for the capacity of your machine:
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F-7701.pdf
There are also a few attachments that can be put on to the No. 12 attachment hub. A few of these are a vegetable slicer-grater and meat grinder.
Mar 04, 2011 | Hobart H600 Stand Mixer
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
Can you use a spiral dough hook when the mkixer runs in reverse?
You can but the dough would ride down towards the bowl instead of up and your mix would not turn out properly.What kind of mixer do you have?i'm a hobart tech and repair these mixers often.Let me know.
Nov 04, 2009 | Hobart H600 Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Motor stalls out when mixing you unplug and plug back in and it will run had the motor checked out and was fine
You are overloading the bowl or you bought this used and when they wore the motor out, you ended up with it. Batters & icings 75% bowl capacity, doughs 65% bowl capacity. If you live by this, you will buy 1 mixer & never have to replace it, especially if it's a Hobart.
May 01, 2009 | Food Mixers
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
MIX7130
ship it back to anvil , buy a hobart ,best mixers in the world
May 19, 2008 | Anvil MIX7130 Stand Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Hobart A200 Stand Mixer Logo
1,084 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
