Question about HP Pavilion a785c (82916061390) PC Desktop
Stuck in start up screen, blue screen <ESC=Boot> <F1=Setup> <F10=System Recovery>
  • jst12fly2 Jan 04, 2011
    stuck in start up screen, blue screen <ESC=Boot> <F1=Setup> <F10=System Recovery>
5 Suggested Answers
SOURCE: Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
Posted on Mar 07, 2008
sayedmohu
  • 635 Answers
SOURCE: wheni cut my computer on,
Your harddrive is not getting detected properly.
Check your harddrive.
Posted on Nov 03, 2010
  • 10406 Answers
SOURCE: on the bottom, it shows
Check that your keyboard is connected, and is working properly.
Try your keyboard on a different computer.
Try a different keyboard on your computer.
The 'ESC' key should always work.
The 'F1' key should always work.
If your disk-drive is *NOT* "dead", then the 'F10' key should work.
If neither 'ESC' nor 'F1' work, you have a serious problem with the motherboard.
Posted on Feb 03, 2011
bronk50
  • 27725 Answers
SOURCE: when I turn the computer on i get a splash screen and at the bottom it says esc=boot ,f1 = setup , f10 =system recovery
Test the leads that attach to your ((hard drive from the motherboard)) make sure they have dust free secure connections or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive)) if its a 40 pin IDE this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs continue its cycle power and data to travel through every working device and have an end point so any faulty leads will end up with a computer error
Posted on Nov 29, 2011
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
What keys do I press to get the CMOS setup screen on a Compaq Presario 5222?
Try F2 or F8 or F9. Shouls tell you just before the splash screen comes up ...
Jan 28, 2012 | Compaq Presario 5222 PC Desktop
On the bottom, it shows &lt;esc=boot menu&gt; &lt;f1=setup&gt; &lt;f10=system recovery&gt; but it doesn't respond to anything or move from this screen
Feb 03, 2011 | HP Compaq Presario SR1850NX (ER925AA) PC...
My hp 519j XP freezes when I reboot or if it sits on for awhile -- screen shows on the bottom: &lt;Esc+Boot Menu&gt; &lt;F1=Setup&gt; &lt;F10=System Recovery&gt; but those 3...
press del and get into bios click optimizes settings then save and exit if still the screen doesn't go further remove the power from the hdd and the ide cable or sata cable and remove all the add on cards and restart the system when you restart you find no boot device connect the ide to the primary ide connector and restart your computer if the page doesn't show no boot device change your ide cable
Dec 15, 2010 | HP Pavilion Desktop, 3.06GHz Intel Pentium...
I have a HP Touchsmart IQ500 that is a little over a year old. It was working fine and I went out one day to come back and start it up to find it was only a blue screen with a few options.I found someone...
This might be an issue with the Hard drive or the operating system installed on the hard drive.
Try to access BIOS screen tapping on F10 on restart.
If you are able to access Bios try to run the Short smart self test on the Hard drive.
To run the test follow the steps as follows:
on the main window you will see 1 st drive 2nd drive 3rd drive 4th drive.
besides these drive letters you will find your Hard drive listed.
Highlight that and press enter.
on the next screen highlight Smart support and press enter.
on the next screen select Short smart self test and run the test.
If it gives an error code that means the hard drive has gone bad.
2)If not then come back on the main page by clicking on ESC button till you come back to the main page.then Press F5 select yes to load set up defaults and press enter.Press F10 once to save configuration changes and press enter.
It will boot to windows.
3)Still if you face the same issue then you need to perform the recovery using the recovery cds.
4)If you don't have the recovery cds then you can contact HP support and order the cds and perform the recovery.
This should resolve your issue.
Thanks.
Aug 20, 2010 | HP Computers & Internet
Recovery problem
you need the cd to restore any vista laptop call acer and order one sorry
Sep 02, 2009 | Acer Aspire 5610-4648 Notebook
I cant install a new operating system into my HDD. My setup does not suportt boot from CD.
The Bios Settings need to be changed to boot from The ATAPI drive. When you turn on computer press the F2 or F1 or Delete button, sometimes its F10. Once you are in the bios setting look for boot devices. Follow the on screen instructions to change the boot order. I hope this helps.
Mar 30, 2009 | IBM NetVista PC Desktop
Takes 15 mins to boot after loading Micro trend
you have too much at startup. thats the programs the computer starts at boot up.i would go to last good configuration and see what happens if that works i would seriously get rid of some programs you don't need and defrag your computer.
Dec 15, 2008 | HP Pavilion a1600n (882780776265) PC...
Mar 06, 2008 | Computers & Internet
HP Pavilion a785c (82916061390) PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
