Question about Dimplex BPC-2007 Electric Grill
My Dimplex BPC-2007 Electric Grill has no power after it plugged in ?? very briefly i see power at the temperature controls bu no power to any controls? cant turn it on with on/off key pad control??
Sounds like you need a new control panel and if it is within warranty, Dimplex will send out parts and service.
Posted on Jan 07, 2011
    New Friend:
Who can work on my traeger grill.
Posted on Apr 17, 2014
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
How to grill
It's simply a plug and play machine ;) This model has a temperature control.....which I don't exactly know how it works.....but I always keep mine toward the middle/center....and my black angus patties are typically done within 10 minutes cooking time.....
Jun 07, 2014 | George Foreman GR30VT Indoor Grill
Dimplex optiflame remote not working
The DFI2310 uses a simple plug-in remote.
You can either order one from Dimplex, or use an aftermarket solution such as this one from Skytech: Skytech 1315G Electric Fireplace Remote.
Oct 08, 2012 | Dimplex DFI2310 23 Inch Deluxe Electric...
How to operate the Dimplex CS1205 Compact Electric Stove. How to activate the heat and is there a temperature control switch?
Here's a link to downloads owners manual.
http://www.dimplex.com/cms/publications/CS1205_-_7207040100R06_EN.pdf
Sep 18, 2011 | Dimplex Compact Electric Flame Stove...
I have a Dimplex electric grill like the BPC one and it won't come on. Plugged in and nothing happens. It was purchased late summer 2010
If you still have your Proof of Purchase, it's still under warranty. Contact Dimplex USA, Customer Service at 800-668-6663. If you don't have your Proof of Purchase contact Dimplex USA, Technical Service at 888-346-7539. But, before making any calls, check the receptacle that the grill is plugged in to, to make sure it's functioning. If it isn't then the circuit breaker for that receptacle has been tripped and needs to be reset. Reset the breaker without anything plugged into the receptacle. Then plug the grill back and turn it on in to see if it tripped the breaker. Often times, the receptacle itself can be at fault and may need to be replaced.
Hope this helps your solve the problem.
Mar 19, 2011 | Dimplex BPC-2007 Electric Grill
HI THE 3 INDICATER LIGHTS WERE ALL ON SHOWING THAT THE HEAT SHOULD HAVE BEEN ON FULL CAPASITY!!BUT THERE WAS NO HEAT BLOWING OUT OF THE GRILL!!
Not an unusual problem with any electric fireplace heater. I suspect the overheat circuit has shut the heating element down. Or the element has burned up (that's not unusual either).
In any event, turn the fireplace OFF and unplug it. Wait 30 minutes before plugging it back in. During that time, the overheat circuit may reset itself. If that fails to solve the problem call The Technical Service Dept of Dimplex USA at 888-346-7539, Monday - Friday, 8:00 a.m. - 4:30 p.m. EST. If it ends up needing parts, you can order them at that time.
Have the Model # and Serial # of the fireplace, handy. As you will need to provide that information to them, as well as the date of purchase.
Mar 02, 2011 | Dimplex DF3003 Electric MidSize Heater
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
DF3015 electric fireplace insert- unit is plugged into power outlet but does not turn on.
The blower is controlled by a thermostat and will only come on when it's hot. If still does not come on check thermostat.
Jun 28, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
New Plug and Cord for Wolfgang PuckĀ® Reversible Electric Grill/Griddle
I also need a replacement electric cord for the Wolfgang Puck Reversible Grill. Please let me know if you are able to locate one.
Oct 19, 2008 | Wolfgang Puck 781698 Indoor Grill
GRP99
Everything you described is normal, except not heating up.
When you first plug it in, you will see 'dashes' that tell you it is getting power.
When you press the Power Button, the grill will start at the Default Temp of 300F and the Timer starts at 5 minutes. You now change the temp to what you want.
It takes 5 minutes to get your grill to your tempreature, so the timer should 'count-down' as the grill heats up.
As for not heating up, I think you will need to get that 'looked at' for repairs.
Mar 18, 2008 | George Foreman GRP99 Indoor Grill
Dimplex BPC-2007 Electric Grill Logo
236 people viewed this question
Top Dimplex Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Dimplex Grilling Expert? Answer questions, earn points and help others
