Question about Roper RAS6233KQ Top Load Washer
My washer will spin but very slowly. Motor and shaft spins out of washer.
  • 23 Answers
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Posted on Jan 20, 2011
  • Ken Compton Jan 20, 2011
    I need to correct my earlier solution. The machine should not try to spin while it is draining. So if it spins slowly, there may still be too much water in the tub. Easy to check and rule this out first. Open the lid and insert a small screwdriver in the hole by the lid rest to activate the lid switch, DO NOT PUT HANDS IN THE MACHINE while doing this test. Check to ensure all water is drained from tub before it attempts to spin. If there is still water in tub at this point, there be drain hose blockage or the drain pump is malfunctioning. If all water is drained and it still spins slowly, then either the motor coupling is slipping or there is a tub clutch problem.
The door is closed good. However, the washer will not spin.
if it spins slowly but atleast spins? You may have a slipping clutch, bad brake assembly or if belt driven a loose or worn belt. maybe even a worn down motor coupler
Sep 15, 2014 | LG WM1814CW Front Load Washer
Ge washer 175d2750g116
Check for a loose grub screw in the pulley that is not transferring the shaft motion to the pulley. It will ne a hex hole and will require an allen key to tighten it uo
Aug 17, 2013 | Washing Machines
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
Washer spins slowly
your clutch pads are worn out they sell a kit to repair that
Feb 04, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer drains but won't spin.
the first thing you should check would be that you had pressed the motor coupling far enough onto the motor shaft and the the shaft on the gear case the shafts should be flush with the coupling if not this will cause a bind on the motor and also cause it to have a hard time starting
Mar 25, 2009 | Kenmore Washing Machines
Kensmore 70 series
Often times, the coupling is not fitted completely, and the excess pressure is binding the motor or gearbox up
Not a guaranteed solution, but something to check
reopen the case and motor, and use a dowel and hammer to ensure the spiders are fully pressed onto the gearbox and motor shafts
Jun 30, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore Washer No Spin >> Motor problem
It's probably the motor coupling. Same thing is happening to me, but I can not gain access to the motor
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
143 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
