Question about Whirlpool RF367 Electric Kitchen Range
I have the Whirlpool RF368LXKQ range. I turned the autoclean on and about a minute later FSE 1 appeared on the led screen with a beeping sound. The oven door will not open now.
5 Suggested Answers
  • 409 Answers
SOURCE: whirlpool gs475lems range oven problems
it means bake range over temperature.
have a technician check out the oven temp sensor. you may have a short in wiring or it may need to be replaced.
if problem still persists, replace the clock.
Posted on Sep 13, 2008
SOURCE: Oven element started to spark
See this for description of same issue:
http://forum.doityourself.com/appliances-large-electric/255234-ge-electric-range-oven-element.html
Posted on Jan 24, 2009
jonniewalker
  • 1029 Answers
SOURCE: gas oven door locked after autocleaning-- will not
set the selfclean and after you hear it lock down then cancel the operation and wait to give it time to unlock ,,, may take up to 10 minutes ,,, if it dont unlock you will need to get into the back of it and run the door latch back by hand
Take the back cover off the the stove. UNPLUG THE STOVE
On the left rear facing the back of the range youll see that the timer motor had stopped.may sure you unplug the input(230 volt power) leading to the stove, then unpluggand insulate the wiring to the timer motor and the microswitch on top of it ( 4 wires). Then take the long steel wire off of it and unlatch the oven door.
this probably had something to do with the timer motor on the self cleaning cycle and that it was stuck
Do NOT use the self cleaning function unless you fix the timer motor. Replace it or clean it.
Hope this helps
Posted on Apr 06, 2009
my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Posted on Dec 21, 2013
Rnage RF367 getting code FSE 1 and oven door will not unlatch to open
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Dec 30, 2011 | Whirlpool Kitchen Ranges
Oven won't heat up
oven won't work got power to safely valve and gas come from regulator
Oct 11, 2009 | Whirlpool GS460 Gas Kitchen Range
Range intrupted during autoclean - oven remains locked.
Pull out the range and unplug it. Remove the back and look on the side wall for a small disk [the thermal fuse] with two wires attached to it. Remove rhe two screws holding this disk to the wall of the range, then pull off the two wires and temporarily patch the two wires together using some electrical tape. Now plug your range back in. IF the door unlocks you will know that your thermal fuse must be replaced. It will cost about thirty dollars at your local appliance parts store.
Apr 29, 2009 | Kitchen Ranges
I put on a pizza and hit the autoclean button by mistake. How do I shut off the autoclean?
You have to go to the circuit breaker box and shut the switch that powers the stove, then turn the switch back on and it will release the auto-clean!
Feb 19, 2009 | Whirlpool Kitchen Ranges
Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Jan 11, 2009 | Whirlpool RF364 Electric Kitchen Range
Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Nov 22, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool oven
When I had a similar problem, the door wouldn't unlock even after unplugging, waiting 30 minutes, and plugging the oven back in. I finally had to manually unlock the oven by turning the lock latch motor myself.
Here's a good page that describes what the lock latch motor looks like and where it's located. Of course, there is 220V current running around inside there, so please unplug before removing the back access cover and put it back on before plugging the oven back in.
My symptoms:
  • Oven failed to complete auto-clean cycle.
  • Oven started beeping; control panel showed FSE 1
  • About a minute after plugging in, oven started beeping and displaying FSE 1 again
Once I unlocked the door manually and plugged back in, the oven started behaving normally.
Jan 01, 2008 | Whirlpool RF368 Electric Kitchen Range
Whirlpool RF367 Electric Kitchen Range Logo
102 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
