Question about Nintendo Wii Console
My rechargeable battery packs have not stayed charge since i got them.
  • 839 Answers
There are series of problem in Nintendo wii which can be solved without much technical knowledge........ Your problem belongs to that so don't worry i will give you the link to download the Nintendo repair guide that will help you a lot...
Click here to download Ninento wii repair guide
Posted on Jan 04, 2011
Motorolla walkie talkie shuts off when PTT button is pressed... Driving me INSANE. Please help
This is usually a low battery issue. If you are using the rechargeable battery pack, does your Motorola unit accept regular batteries in place of the rechargeable battery? If you can put in 3 or 4 AA batteries (depending on the model), try that. If the radio stays on when you press the PTT button, then continue using the regular batteries or get a replacement rechargeable battery, if you can find one for the model. If the radio still turns off when you press the PTT button with fresh batteries, then replace the two-way radio.
I hope this helps. When the rechargeable batteries fail, they will still charge but they won't hold a full charge for as long a period.
May 20, 2018 | Radio Communications
Battery will not hold charge
This is an indication of memory in a battery or failing battery in the pack. Batteries should be run until they are flat then recharged and never recharged when they are part charged as they develop a memory of that charge point that the charger cannot overcome and will not charge past. If the battery in a pack has failed then there are battery re-acker shops that can replace batteries in a pack cheaper than a new battery unit and most probably with better batteries.
Jul 27, 2013 | kawasaki Drills
Both green and yellow light stay on and batteries will not charge 18v
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Oct 19, 2009 | Ryobi Multi-Volt Battery Charger
Both green and yellow lights come on and stay on.
replaced.
Jul 12, 2009 | Ryobi Multi-Volt Battery Charger
Cant charge battery pack for wii fit balance board
You may want to send an email to customer.services@gem.co.uk. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
Jan 27, 2009 | Nintendo Rechargeable Battery Pack 3600mAH...
Recharge batteries in camera on g610 printer dock?
Hi, I think I can answer your question, i just tried something with my camera and camera dock.
My camera came with a Kodak battery pack(pack that looks like 2 batteries connected together). When I place my camera with this battery pack in it on the dock, a green light comes on on the dock and the batteries begin to charge. However, when i place any other rechargeable batteries in the camera on the dock, it has no effect, my theory is that it must be a battery pack, possibly by the same manufacturer so that it will charge correctly
Dec 20, 2008 | Kodak EasyShare C613 Digital Camera
New Haier 7.2V rechargeable NI-MH battery pack for a new Haier Portable DVD player was stored in a drawer for 2 years until recently. Attemped to recharge battery pack via electrical outlet. Obtained...
the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
Oct 02, 2008 | Televison & Video
Pocket Vsmile
Maybe you have to buy a new rechargable battery pack. I have had one before and for some reason it no longer charged well. It too would hold a charge for only a small period of time, definately not long enough to appease my daughter! :) Try giving vtech a call and see what they say. At the very least they can help you get a new pack. Here's the number! 1.800.521.2010 :)
Aug 24, 2008 | Vtech V.Smile Pocket
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
