Question about Kenmore Dishwashers
Model 66517772990 is LOCKED and won't let me unlock it via the NO HEAT button as described on the instruction panel.
5 Suggested Answers
  • 219 Answers
SOURCE: Maytag Freezer Door Panel Locked
replace the front board but read your manual first because some lock without it saying it has the lock feature by hitting 2 buttons for 3 sec at the sametime locks and unl;ocksit
Posted on Mar 19, 2009
rylee_smith
  • 8619 Answers
SOURCE: I have a Kenmore Ultra
Hi
Thanks for using FixYa. To resolve this issue try to press and hold the NO HEAT DRY/Air DRY button for 15-20 seconds, if this won’t resolve the issue then you’ll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 10, 2010
SOURCE: Describe your hisense tv ~20in(?) Flat Panel TV. I
I HAD THAT SAME PROBLEM ALL YOU DO IS HOLD THE MENU BUTTON UNPLUG THE TV AND PLUG IT BACK WHILE STILL HOLDING THE MENU BUTTON GO TO GENERAL SETTINGS AND TURN ON RESET MENU ON FROM THIER AUTO SEARCH YOUR CHANELS NOW U CAN HEAR THE TV BUT BLACK SCREEN NOW UNPLUG YOUR TV FOR A FEW MINUTES PLUG IT IN AND YOUR TV SHOULD BE BACK ON THIS IS THE 3RD TIME IT HAS HAPPEND TO ME IT WORKS
Posted on Dec 06, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Describe your how to unlock
Sorry to read about your problem, I hope this helps you out.
thier is no lock, you have to slide the covers, and their is nothing in the heater to turn up the heat, the only way to adjust heat is thru the thermostat on the wall
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Control locked light is on. Have replaced control board but control still locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
May 28, 2015 | Whirlpool GEW9250 Electric Dryer
How can I set the timer on this ?
Open the panel below the screen. The owner's manual pdf is linked below. pg 4 describes the setting procedure. Note the warning that if you have locked out buttons using the remote, you will need to unkock them prior to setting clock. Instructions for unlock (pg 17) hold down 'Filter' button" press & hold "ON/OFF' for 2 seconds. The word locked should disappear from screen.
http://www.mitsubishielectric.com.au/assets/LEG/IB_PAR-21MAA_1%28WT04474X01%29.pdf
Nov 27, 2012 | Heating & Cooling
Control locked light is on on my whirlpool duet front load dryer and it won't do anything
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
Thanks
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My control panel reads "Control locked". How do I unlock?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a Whirlpool duet, model GEW9250PL0, and the control panel is locked. I tried holding the signal button to unlock it and that didnt' work. Any idea how to reset it?
Aug 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked on whirlpool ghw9100lw1
Mar 27, 2010 | Whirlpool GHW9100L Front Load Washer
Machine controls are locked out and it will nto start up
Sep 01, 2009 | Kenmore Washing Machines
My control panel is locked on my Duet Wirlpool washer model # GHW9150PW1 how do I unlock it?
If this does not solve your problem, or if you have additional questions, please let me know.
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Oct 15, 2008 | JVC TH-C60 System
Dishwashers Logo
76 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
