Question about Whirlpool Washing Machines
The computer is on the fritz in my front loading "Duet" washer. I was washing some clothes and the door won't open - they can't send a repairman until Friday and this happened on Monday. I need to get the wet clothes out and I've tried everything the instruction book said. PLEASE HELP before my clothes ruin.
  • MarilynFrye Jul 10, 2008
    Thanks so much for the help. I am at work and haven't tried it yet. My clothes have been stuck (wet) it the washer since Monday and it is Thursday!!! I have been waiting on a repair man since the end of May. (one assigned through the Sears warranty!)
  • 5,911 Answers
You need to access the manual release for the door. Click on the following link for instructions on how to do this:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
In some cases simply using the manual release will reset or clear the problem. Once you get your clothes out, try running the washer with no load to see if it will run error free. You may be able to cancel that service call.
Posted on Jul 09, 2008
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool front load washer will not open, even when the "done" light is lit. Any suggestions on how to get my clothes out?
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet hp washer has a musty smell. i have used bleach several times but so far no help.
Clean the washer with Smelly Washer Cleaner or such product. Never close the door when not washing clothes, leave it open to air out
Jun 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud message on whirlpool duet front load washer also after washing clothes i notice a mildew smell on the clothes.
You areusing too much soap. Run a rinse cycle and use less soap next time. As for the mildew leave your door cracked open after you are done using the machine.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My clothes are stuck in my front loading whirlpool washer. How do I open the door manually
The following link explains how to open the door manually on a Whirpool Duet:
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odor in clothes
run an empty load in the washer but add 3 cups of vinager and set the washer to hat wash, this will help kill the smell, After you get done running it leave the door open this will stop it from happening again
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When I wash comforter in whirlpool duet front load water comes
first an foremost your washer isn't designed to wash comforters, the capacity isn't large enough. only clothes sheets . the reason ur door wont stay closed is the bulk item is pushing it open. overloading washer will cause $$ major problems. simiply take that to the cleaners an save urself some big bucks.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
