Question about Tomtom GO 700 GPS Receiver
How to reset tomtom go 4v00.710 - Tomtom GO 700 GPS Receiver
Tom tnm go 4v00.710 wont start after charge
Posted on Sep 16, 2011
SOURCE: tom tom 710
Theres a tiny hole at the back if you look with a torch where the TomTom connects to the cradle
Posted on Nov 30, 2007
SOURCE: Battery replacement for TomTom 710
I have found a trick for those bad battery ,but you lose your waranty
you need to open your tomtom , behind the screen you wil find the battery(for the Go 710 it is an 3.7 V ,2400mAh,samsung ICR18650-24)
you find 3 wires : red, black,yellow cut them of at the half of the wire size
, then cut off your car loader wire (tomtom)(5v), you will see again 3 wires inside :red,black,white
connect the red with red, black with black, white with yellow
(the best thing is to make a little hole in the cover to pass the wire, so it will be beter for closing the all thing)
I did it and it works pretty fine ,I had save 30 dollars ;) :D
I did in approximatly 30 min
remember you will have no battery any more and no waranty of tomtom!
It only whorks then with your car loader tomtom
Posted on May 29, 2008
  • 9 Answers
SOURCE: my tomtom go 710 4v00 will not switch on
Fix it yourself, you need either a new battery and or motherboard. Relativly easy to do! 10 small torx screws for motherboard and 2 ribbons, then a few more screws and loosen the harddrive and screen for battery
Battey and motherboard for less than £50 pounds off ebay
Posted on Aug 22, 2009
  • 44 Answers
SOURCE: Tomtom 710 will not turn on . I can't find a
If battery gas been completely flat, you will need to hold the power button for a few seconds
Posted on Oct 06, 2010
SOURCE: tomtom 710 broken
there is a small reset button you can push with a pin. Revived my "dead" 910...
Posted on Apr 08, 2008
How do reset my tomtom 20
Press the power button down and hol down for approx. 20 seconds. When you hear the tomtom 'drums' let the power button go and wait about 60 seconds for a full reset and boot
Mar 12, 2013 | Tomtom One Europe v2 GPS Receiver
How do i reset tomtom
press the reset switch for 20 seconds or if newer model hold down te power switch for about 20 seconds until you hear the tomtom drums then release
Tomtom wont turn on after chaging it
Reset your TomTom GPS receiver. Some TomTom users report occasional difficulty in getting their TomTom navigation device to start or respond to commands. If this happens to you, remedy the problem by performing a soft reset on your TomTom GPS. A soft reset will reset the data on your TomTom GPS receiver without erasing any data. To reset a TomTom GPS receiver, press and hold the "On/Off" button for 15 seconds or until the device restarts.
Let your TomTom GPS acquire the necessary satellite signals outside. If the device has trouble connecting to the satellite signals necessary for its operation, try an easy fix to the problem. Take your TomTom GPS receiver outside, away from mountains, tall buildings or heavy foliage, where the receiver has a clear view of the sky. Wait for a few moments while the device acquires the necessary satellite signals.
Read more: How to Troubleshoot a Tom Tom GPS ' eHow.com http://www.ehow.com/how_5533906_troubleshoot-tom-tom-gps.html#ixzz1hV4FBQ91
Dec 21, 2011 | GPS
How do i perform a hard reset on my tomtom xxl 540 to reset it back to the factory settings?
For the TOMTOM XXL540 while connected to your PC hold the poer button down for about 15 or 20 seconds the device will shutdown then restart when reset
Apr 16, 2010 | Tomtom XXL 540S GPS Receiver
I plugged the system in, the screen would not come on
Hi.
First check the charger connection. If an alternative charger is available test different chargers.
If the Tomtom is starting, then try first resetting your TomTom.
To reset the TomTom follow the instructions on TomTom website, clicking here: TomTom, portable GPS car navigation systems - Factory reset .
If the Nav is still freezing or is dead after reset, then there is an internal fault.
In both situations the alternatives are going to a TomTom shop or calling the TomTom service number listed on manual and following the instructions given by their representatives.
If the unit is completely dead, as a first thing better going to a TomTom shop and asking to test a different charger.
The charger can also be tested at home using a multimeter on charger connector.
Regards.
Jan 03, 2010 | Tomtom ONE GPS Receiver
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
When i turn it on it freezes.
Hello, I own a TomTom also. I have listed the procedures from TomTom Home and hope this will work. First try a soft reset (Reset button is located at the bottom of the TomTom device next to where the DC plug plugs in). Make sure your batteries are fully charged up or the USB cord is plugged in.
If your device is not starting up properly, follow the steps below:
  1. Soft reset your device. *
  2. If your device still does not start up, then reinstall the TomTom application using HOME
If you have backed up your TomTom to your computer, then you can reinstall the TomTom application from your backed up data. *    In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
Jan 16, 2009 | Tomtom ONE 3rd Edition GPS
I upgraded the tomtom via tomtom home and it will not start
Jan 10, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom GO 700 GPS Receiver Logo
1,700 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
