Question about Coleman Heating & Cooling
I have a honeywell LR1620 in my appt. and it runs off a boiler set up that heats my unit. My question is my landlord does not like me turning up the hear pasted 70 ( i keep it about 72-74) and he enter my appt when i was gone and my friend was over using my computer. The landlord did something to the thermostat according to my friend he used a tool that look like a small screw driver. Now my heat will NOT go above 69 degrees. Did he adjust the anticipator? did he somehow rig it so if i turn it up to 80 it wont work? I set it to 50 today and it still stays at 68...
  • Coleman Master
  • 43,501 Answers
He probably put a screw or a couple of screws in there so that the setting cannot be changed...either up or down....
Basically he "locked" your t-stat to one temperature....
I guess that it his right as your landlord.... the only other thing you can do is to buy a small elctric heater to supplement the heating system when you are there...
heatman101
Posted on Jan 04, 2011
I have a Honeywell L7224U I need to know how to turn on the circulator
Assuming you have an oil fired unit. hot and neutral wires on circ should be connected to C1 and C2 respectively. Tstat should be connected to TT which will energize circ on a call for heat and boiler will run based on limits. If you boiler is set for cold start the circ will only run on a call for heat. If you have more than on tstat/zone then you probably have either a zone control box or zone valves and transformer. If that is the case I would defer to a heating professional.
Nov 16, 2017 | Honeywell Heating & Cooling
Honeywell lr1620
I do not believe that LR1620 is a model number, you may need to find another number. Try this link to see if maybe it's your thermostat or not. The stamp LR1620 is actually on multiple thermostats. Hope this helps!
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0107.pdf
Read down the PDF file till you see the instructions on setting the heat anticipator.
Dec 01, 2013 | Honeywell Heating & Cooling
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
My timer is set to shut off at a certain time of day, and I want to turn the timer off, but I can't figure out how to do it. Can you send instructions on how to turn the timer off?
Honeywell product is not identified.
More information is needed to identify product. Add a comment with as much information as possible, to help expert locate correct information.
For example Honeywell makes timer controls for boiler and heat-ac units.
Honeywell also makes Aube brand wall and box timers for lights and pumps.
http://waterheatertimer.org/Aube-timers.html
Honeywell has a contact-us page:
https://honeywell.com/Pages/contact-us.aspx
Aug 30, 2011 | Honeywell 24-hour Timer Control 120v Spdt...
I have a Honeywell LR1620 Thermostat that I am replacing with a Honeywell RTH230B. I se where all the wires go to on the new thermostat EXCEPT the blue wire that is attached to the "W2" terminal...
If your old t-stat had a W2 terminal with a blue wire connected, and your new t-stat does not have a W2 terminal, then you may have purchased the wrong t-stat. The old is a 2 stage heat where your new is a 1 stage heat. 2 stage heat means the tstat will engage 2 heat elements, then if it continues to get cool inside, the Tatar will engage w2 and the remaining 1 or 2 heat elements. If you want it like it was to begin with, you'll need a 2 stage heat 1 stage cool tstat.
Oct 10, 2017 | Heating & Cooling
I have a Honeywell ST499A/ST699B "Central Heating Microelectronic Time Controller" managing the operation of my house boiler. The time controls are set properly. PROBLEM: If I want either hot water or...
I have an old Honeywell ST499A/ST699B thermostat. It still works OK but when we have a power cut I have to re-programme everything. Presumably this is because the battery needs replacing. I cannot find a way of opening the control box to get into the unit to replace the battery and in any case I’m not sure if the battery is renewable?
Oct 12, 2009 | Honeywell Programmable Thermostat Heater
Off - Service Due = no hot water what am I supposed to do?
Called the Gas man... fiddled with some buttons, over-rode the system. All fine now.
Sep 29, 2009 | Honeywell Electronic Programmable...
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
200 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
