Question about Sony Cyber-shot DSC-W50 Digital Camera
Lens stay extended, no picture in view, says turn camera on off--no response
  • Sony Master
  • 4,924 Answers
It seam to be a common issue with this model ...some says that they strip it down and worked when they put it back ..(seam like a physical jam of the lens...) other that during the stripping they removed the card and worked after that (memory card ) so it can be a error ..
I suggest to try it if you are handy enough ..cause it is either a loose contact to the lens motor ..or just a physical issue with the lens ...and the motor do not have the power to retract them ..
If not ..just get it to someone that knows the way around it ...if you think you cant manage ..
Posted on Jan 05, 2011
  • Catalin Turcu
    Catalin Turcu Jan 05, 2011
    By the way ...try a good shaking ...if it is stuck ..it may loose itself ...after that power it on and off a few times and do remove the card to have more power..
I have a casio digital camera qv-r52 3x optical zoom when I turn power button on it will not stay on the lens retracts but I can view the pic's on the dish
Katie, Joe alerted me to your problem. The symptoms that you're experiencing suggest that you're experiencing a lens error. Lens errors are fairly common, but there are many causes. Some causes include poor or drained batteries. Or sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 16, 2011 | Casio Cameras
When i turn my camera on, its a blank screen with
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 03, 2009 | Canon PowerShot A75 Digital Camera
Dropped my exlilim ex-s880 in the sand and can view pictures only
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Oct 11, 2007 | Canon PowerShot A75 Digital Camera
Camera won't turn on/lens extended
General system failure- Contact Samsung for repair cost.
Aug 30, 2007 | Samsung Digimax S500 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
16 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
