Can I reset the amount rings before my fax picks up? I have an HP OffcieJet 6110 all in one. No one at HP seems to know the answer.
  • 3 Answers
Hi there, there should be an option in the menu to change the number of rings before answer between 1 and 6 rings, as per the doc in the link below.
T
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00059737&cc=uk&dlc=en&lc=en&jumpid=reg_R1002_UKEN
Posted on Jan 04, 2011
How do i set the number of rings befor the fax picks up
Press 'MENU', Move to 'BASIC FAX SETUP' using right arrow key & press 'Enter', move to 'RINGS TO ANSWER' using arrow key & press 'Enter', enter desired no. of rings and press 'Enter'. The fax will answer after the set no. of rings in 'AUTO' answer mode.
Oct 20, 2014 | HP OfficeJet 6110 All-In-One InkJet...
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
Can I change the amount of rings before the fax picks up?
Yes you can. You can press the Menu button and advance to Fax Set up or Advance Fax Set up and you will find the option in there. You can also google hp Officejet 6110 all-in-one Manual and it will take you to a site where you can download your own copy for this little wonder. Good luck.
Jan 04, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Hello! My fax will not answer on my HP OfficeJet
Please oress the button "auto awnser" on the printer which is on the left of the printer front panel under FAX. Once we press the button the libht should glow.
This will fix the issue.
May 17, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
CAN'T GET FAX TO WORK
turn off answering mech. count # of rings before fax answers add onemore ring to answering mech. before it answers.
Dec 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
FAx Line will not pick up or send faxes on HP 6110 All in One Officejet
it seems like you have lots of services on your line. here are the things that i want you to follow to somehow resolve the issue.
1. Press the setup button on your printer, then use the arrow down button to scroll down and go to ADVANCE FAX SETUP.
2. Press okay on Advance fax setup, then it will give you options.
3. The first option is DISTINCTIVE RINGS, press okay on that.
4. It will give you first option "DISTINCTIVE RING", scroll down and look for "answer on double rings" then press okay. then try letting someone send you a fax.
Note: make sure that your answering machine is using your home telephone line so that it wont affect the faxing functionality.
1. if the issue still not resolve, try to press setup, then go to TOOLS.
2. press okay on TOOLS and it will give you options, scroll down using the arrow down button and look for RUN FAX TEST.
3. Check the result of the test if everything passed!
Let me know if the issue still not resolve so that i can go ahead and give you additional steps.
thank you so much.
adonscott
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
I need to change the ring time on my 6210- how do I do it?
Press the Setup button on the control panel > press ok > go to Basic Fax Setup > press ok > go to Rings to Answer (choose Rings 2) .
Thanx
May 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Changing the amount of rings
Pick the phone up earlier it will stop ringing......:-)
To set the number of rings-to-answer
To set or change the number of rings-to-answer, use the following steps:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Fax setup, and then press tick
3. Use the < or the > button to select Fax Recv. setup, and then press tick
4. Use the < or the > button to select Rings to answer, and then press tick
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press tick
But I still think picking up the phone earlier would be easier
Your Manual, please rate as fixya or post back
Dec 28, 2007 | Office Equipment & Supplies
Cannot receive fax but everything else works
Is the fax receiving setting set to "auto" or "manual" receive?
Jul 07, 2007 | HP OfficeJet 6110 All-In-One InkJet...
21 people viewed this question
jasbo
jasbo
