Question about Montgomery Ward (223600UP) Heater
MODEL SFB50145A MILLIVOLT OR 24VOLT - Montgomery Ward (223600UP) Heater
  • Montgomery Ward Master
  • 43,501 Answers
If there is no cord to plug in ....it is millivolt...if it has a cord then it is 24 volt...
heatman101
Posted on Jan 04, 2011
How do i light the pilot light for the hayward
The lighting instructions are usually located inside the heater on the inside of the access panel or on the firewall near the gas valve.
Most millivolt heaters require you to turn the gas valve knob to the pilot light position and then depress the knob while lighting the pilot through the pilot hole. This varies depending on the exact model.
Aug 07, 2012 | Hayward 250 1 Millivolt Propane Pool...
Looking to find out if my gas fireplace unit has a "milli volt gas valve" to change it to a remote control unit. Model # CGG363OP Is this remote capable and if so can you sell me a remote for...
Marty, I would really like to help you, but the DESA/Comfort Glow Model Number you listed is incorrect. Please check & confirm it and get back to me.
To visually tell if your gas control valve is Millivolt or not. First, look at the pilot assembly. If it has a thermopile attached to the top of the pilot, it's millivolt controlled. If you are currently using a wall switch to turn the burner ON, it's millivolt controlled. If the control valve has 3-electrical terminals on the side of it, it's millivolt controlled.
As far as selling you a remote control kit is concerned, we at FixYa do not sell any products of any type. But, you can buy them from a hearth store in your area or online. I would recommend looking for a SkyTech Remote Control Kit, as they are one of, if not the best on the market. Plus, they come in a a host of models depending on what you want the remote control to do.
Hope this helps you and thanks for choosing FixYa.
Sep 08, 2011 | Desa International Heating & Cooling
SF error
IDXLTER1930
I think you must be mistaken about your heater being a millivolt heater. They have not mfg these heaters for some time. And they probably would not give you an SF error. If you have an SF error, it is a newer model with a digital board. Millivolts usually have two analog temperature dials on them and no digital readouts. That should be the part. HTH
May 20, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Can/ how to adjust millivolt seeting for a lower power pump?
Before you do anything, check with Hayward as to the minimum flow they require to maintain safe temperatures in the heater. You may have to throttle the heater back. They may have a lower value pressure switch you could use, too.
May 14, 2010 | Hayward 2001 Series Millivolt Gas Pool...
I need a new thermostat for a Montgomery Ward SFB50145B wall furnace but I do not know what model or brand to get. Carlos R.
If this is a gas wall heater, any millivolt thermostat will work. Thats millivolt as opposed to a 24 volt type. There should be only 2 wires and the thermostat is just a switch.
Jan 31, 2010 | Heating & Cooling
My pool heaters starts to hum and the service light comes on
millivolt heaters generate their own power from the flame on the pilot max is usualy 750 millivolt, check all connections clean and secure.
Mmake sure the pilot is lit
Dec 31, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
I have a hydrotherm boiler with a millivolt gas valve and when i go to hook my thermostat wires up the pilot drops way down and my millivolt reading drops to 16mv why is that
Make sure your thermostat can be used with a millivolt system.Most thermostats are for 24 volt systems and don't work for millivolt systems. Also your thermostat wiring cannot be too long and it also needs to be the correct gauge. Normally the thermostat wire size should be 18 AWG up to 50 feet in distance. Also all your wiring connection have to be clean and tight(solid connections). If your connections are the slightest bit loose your millivolts will drop.
Nov 08, 2009 | Heating & Cooling
Montgomery Ward (223600UP) Heater Logo
80 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Mack Baxter
gbob59
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
