Question about Jenn-Air WW27430P Stainless Steel Electric Double Oven
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Posted on Jan 22, 2011
    Director Badge:
    Uploaded 100 video answers.
  • Jenn-Air Master
  • 488 Answers
HOW TO REPLACE DOOR HINGES ON KITCHENAID WHIRLPOOL OVEN Check how I do fix this problem. Customer had the same issue. Both doors did not close all the way. If it helps "thumb up" please! Thanks!
Posted on Jul 10, 2014
How to turn off the oven light when door is closed. My stove is 15 years old
  1. Check all the screws behind the oven door gasket - in place and tight.
  2. Check that the door gasket is installed correctly and with all clips locked into place.
  3. Check the center hinge receiver, all screws are in place for the front chassis support
  4. Check the underside of the range below the center hinge receiver and make sure all 4 screws are tight and in place.
  5. Check that the door hinges are installed correctly & both mounting screws are secure.
  6. Check that the hinge retainers are closed and not blocked by the hinge cover.
  7. Check the top of door liner with a straight edge - make sure the liner is not bowed more than the width of a dime.
  8. Loosen the door panel top screws to a "relaxed" state. Open and close the door and retighten screws.
  9. Check the light/latch switch assembly - if out of position or stuck in incorrect position.
  10. If everything checks out, and oven light still stays on, replace hinges.
Apr 02, 2018 | Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Thermador SC302T Electric Double Oven
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
Kenmore oven model# 790.79383401 door not closing
Do the hinges come out with the door or does the door slip off the hinges? If the hinges are on the door then there is no adjustment if not there should be an adjustment but you may have to pull the range out to properly adjust if it is a built in range. Also check the door lock.
Jan 15, 2008 | Ovens
Jenn-Air WW27430P Stainless Steel Electric Double Oven Logo
757 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
