Question about Apex Digital LD4088 LCD TV
Have an Apex digital TV 32".....with NO remote. We've plugged in the dish cable to the cable input BUT we get a "no signal" sign on the screen. it is "stuck" on HDMI1.....because we have no remote to Press "enter".....we can't change in the input. suggestions?
Press the volume button up or down after you have made your input select
Posted on Jan 12, 2011
  • Mark G.
    Mark G. Dec 28, 2016
    This does not work.
HELP!!!! Dish remote 40.0 isnt fully controling Apex tv LD4688T ?
Try an other code. Setup the remote control for an other code to Apex brand. If you wish to get more details, check this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. More than Ten Lakh viewers cannot be wrong.
May 19, 2013 | DISH Network ES190482 Remote 40.0 ES190482
Hooking up a Coby tv 32" to dish network but it says no signal
"No signal" usually means you are on the wrong input. Look at the back of the TV to determine what plugs were used to hook up the Dish box, it will be labeled nearby (like Video 1, Component 1 or HDMI1). Now find the "Source" or "Input" button on the TV remote (it can also be found on the TV) and set it to the input the Dish box is plugged into.
If you are using the Coax cable (the kind that screws on), go into the menu of the TV and run a "Channel Search/Scan". This will find the channel the Dish box needs to be set to on the TV.
Let me know if this doesn't work.
Jan 14, 2013 | Televison & Video
Apex digital LD3288T
Check to see the set is on the right input---the one the Dish is connected to----input or source or even on the Dish remote it is set not to something other than the button for the Dish box.
Jun 07, 2012 | Televison & Video
Remote doesn"t work. Only have
check that all of your cables are plugged in correctly and that the input is set to to correct cables on the remote there is a button that should say input press that a menu will appear and then you can scroll through your input options keep trying until one works
there is also usually a button on the tv that does the same thing
Mar 06, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
LD4088 LCD will not play sound via HDMI cables. Component cables are fine. Hear a faint "click" from speaker when switching to HDMI input. Have tried all three HDMI connectors and have tried...
This is how AUDIO works in HDMI setup, you can select the source to send the digital audio along with the digital video through HDMI, the receiving end HDMI sound setup must be set to receive the digital audio through HDMI. Otherwise the audio may be sent and received through analog audio ports (Red (Right channel) and White (Left channel) RCA jacks) in stead. Most of the new TV and DVD player use auto detection.
So please check the HDMI audio setup to see how the audio signals are set to be processed.
Please leave rating if it helps.
Jan 14, 2011 | Apex Digital LD4088 LCD TV
Looking for remote control code for Phillips/Verizon that works with the LD 4088
This is a solution for DISH NETWORK users that have the remote that comes with the system.
I just purchased my television yesterday and I did the same, as I spent about 3 hours searching online, and found about 600 codes to try, but ultimately, I didn't want to spend a month programming my remote. I ended up calling APEX the company and they gave me three codes: 591, 594, 11531. 591 didn't work for my tv, and 11531 is five digits meant for direct tv users, but 594 worked on my dish remote that came with the dish system. Hope this helps everyone, try the codes for yourself, you don't need to buy a new remote. I was told if these codes didn't work that you would have to call your cable provider to get the additional codes for your remote. The number I called and spoke directly with an APEX Representative was 866-427-3946.
Nov 19, 2010 | Apex Digital LD4088 LCD TV
Remote control code for TWF 32" LCD TV wanted for
Hello
There is no other information available about your Apex TV, other than its user manual. In it there are six numbers given and I quotes it here. Check will it help you or not. OK.
[157_158_159_160_161_162]
Nov 05, 2010 | Apex Digital PF3220 32" TV
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Hooking up tv to dvd player
You will probably have to use your tv remote and change the input for your dvd. It's usually video 1,2 or component 1,or 2
Jul 01, 2007 | Insignia IS-LCDTV32 32 in. Television
Apex Digital LD4088 LCD TV Logo
1,591 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
