Question about Mitsubishi MSM18NW Air Conditioner
Replaced batteries in remote and pushed reset button now unit turns on for 3 minutes and then turns off. does the same thing on repeat. Thanks Kevin
  • 2,133 Answers
Check indoor room temp sensor. And also blower motor's amps.If it's higher than specification, replace motor.
Posted on Jan 04, 2011
How do I reset remote keypad code
Depending on the particular opener you have.. sometimes you press the turn light on button on the wall switch as you press and hold the door open button on the remote. Then it will reset itself and work. Some there is a learn button on the opener motor and you push this while pushing the button on the remote to get them both to sync.
Sep 27, 2014 | Building Materials
I had my glasses off and was on the phone. I was
helllllllo.....take your glasses back off.....hahaha....[a] remove battieries from remote /put them back yes/no...[b] unplug unit & do the battery thing 2/3 minutes,,that should do it...what you did is reset......tkx........see me on amazon/ebay.....bookbundler
Sep 25, 2014 | Televison & Video
Flat Screen 42 inch Vizio does not respond to the remote, called Vizio tech told me to take out batteries and push every button, replace batteries and try. Worked for 3 minutes then stopped again,Replaced...
You can use your phone camera to test the remote. Place the remote to the camera and push to see the IR on the camera. If this works for more than 3 minutes then the IR detector or the processor circuit in the main board is faulty.
This means you need to remove the main panel and use a multimeter to test when the remote is used, trace and see if the fault leads further to the processor.
Jul 18, 2011 | Televison & Video
My remote wont work...the batteries when dead...changed them out and now when you try to use the remote...pushing any of the buttons it says"remote 2" on my dvd player entertainment system
It could be because when you replaced the batteries in the remote, it defaulted back to command mode 1 (DVD 1/MODE 1/REMOTE 1) so the transmitter on the remote no longer matches the unit - you could try pressing and holding both the [2] button and the [ENTER/OK] buttons on the remote for more than 5 seconds, then releasing. Sometimes with Panasonic remote units, whenever the batteries are replaced, the remote defaults back to the original mode. (mode 1); therefore the user needs to recode the remote to match the command of the receiving unit.
Simple enough to try, and costs nothing, except a minute or so of your time. This suggestion should be mentioned in the operation manual for your model system.
Jul 05, 2011 | Panasonic Televison & Video
I have a Sharp SPC502 atmoic clock/weather station. No matter what I do I cannot get the outside temp/humidy to show up on the main station. Have tried changing channels, different alignments,...
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Dec 28, 2010 | Sharp Cell Phones
Cannot reset remote for braemar Ecostar Ducted heatin. Need to reset time and day. Would like to reset programmes also however when i hit the set button as per instructions in little book provided the...
The Braemar heater I have is wired directly to the control unit. The only way to reset the time is to turn of the heater for 5 minutes - the remote display should clear, and turn it back on (takes a minute for remote to come back on) the time will be flashing - use the Up and Down arrows to set the time, and SET button to set the day of week.
Jul 18, 2010 | Heating & Cooling
Power console and Remote no longer control sliding doors or hatch
some remotes have to be reset on the receiver box. lookfor that and push the little button on it
Jul 14, 2009 | 2005 Ford Freestar
I need a user guide for the General Electric GE5805WS3 Weather Station. I can not work out how to set the lunar phases and other basic settings.
1. Install fresh batteries
2. Push the SET button for a few seconds until the unit beeps and the year goes to 2000
3 Push the +/- button to get the right year.
4. Push the SET button again. MONTH will blink
5 Push the +/- button to get the right month
6 Using SET and +/-, go through date, hour, minute, 12/24 hour display and weather estimate. The moon phase will automatically indicate for the date you set.
If you put batteries in the remote before you power up the main unit, it SHOULD find the remote according to the channel that you set on the tiny channel switch in the remote's battery comartment.
Jun 30, 2009 | Kitchen Appliances - Others
I hve purchased panasonic split a.c. b4 1 month only, mi remote senson is not working properly, i mean when i push mi remote button, its effect does not come in mi indoor unit sensor.
Ok, there are a few things to check.
1. Batteries on the remote.
2. Reset remote - switch sometimes in battery compartment and sometimes behind cover, need to press with sharp nib or pen.
3. Check on indoor unit that remote has been selected on the manual/auto switch, located under the cover on right hand side.
4. Remove indoor unit cover complete, (three screws behind the louvers and one on the electrical cover). Change the remote sensor board.
Mar 10, 2009 | Panasonic Heating & Cooling
Palm Tungsten E2, hangs while resetting
Press the power button while pushing in the soft reset on the back.
Jul 01, 2008 | Palm Tungsten E2 Handheld
Mitsubishi MSM18NW Air Conditioner Logo
62 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
