Question about Sony Playstation 3 (PS3) Console
My ps3 system software cannot be run correctly .......THATS ALL ON THE SCREEN!!!
  • 839 Answers
Most efficient and best way is to download the entire repair guide and keep it in our system, we can use this for our personal future use, and you can also refer this to our friends........
Click here to download repair guide
Posted on Jan 04, 2011
It won't send video and audio
1 To reset your PS3 back to its original settings go to options. Select system settings and click reset system. WARNINGFollowing these directions will wipe ALL data from your PS3 system. Do NOT do this,
(this will reformat the HDD)
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
3 After you complete the operation and restart the system, the initial setup screen will be displayed. Follow the on-screen instructions to perform initial setup of the system software. Note that performing hard reset on your PS3 will return your password to 0000. However, note that all settings other than the password will also be reset. Once these settings are reset, they cannot be recovered.
Nov 25, 2013 | Sony Play Station 3 System Backpack For...
Hello I have a problem with my ps3 whenever i turn on my ps3 it says 99% ps3 software update but never 100% can you please help thank-you.
ok when trying to turn on your ps3 dont let go off the on/off button wait till you hear an extra beep and that will reset some stuff and it should let you get that update dont worry it doesnt delete anything just resets software and also it takes the picture of the screen but its still on your ps3 so just put it back on and thats everything enjoy
Jan 12, 2011 | Sony Playstation 3 (PS3) Console
My ps3 comes up with an error when i am trying to do the new update for FIFA 10. Comes up with error 8002ae22... can someone help in normal people terms on how to fix this
If you receive an 800 series error code on the PLAYSTATION 3 system, we recommend performing the following steps which may correct the problem.
Install the Latest System Software Update
To check what version of the System Software is currently installed on your PLAYSTATION 3, from the PS3 Home Menu go to Settings > [System Settings] > [System Information]. The system will display the System Software version number. You can check online to make sure you have the latest version installed.
Restore Default Settings
From the PS3 Home Menu, go to Settings > [System Settings] > [Restore Default Settings]. Once you select Restore Default Settings, you will see a list of settings that will be restored. Scroll through them and press the X button to restore the settings. After the operation is complete, you will see the initial set-up screen that appeared the first time you turned on the PLAYSTATION 3 system. You will need to go through the initial set-up process before you can use the PLAYSTATION 3 system.
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
What games beside ps3 games are compatible with the ps3
It depends on your system the 40g will play ps1, but not ps2. The 60g or above will play both.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
Wont load!
Try going in to the playstation diagnostic menu. This is accessible as follows:
Make sure you have the controller charger cable plugged in and your controller plugged in before you start. While the PS3 is off press and hold the power button, the PS3 will start, beep 3 times and then turn off again. Once it's switched off take your finger off the power button for a second or two then put it back on, listening out for two beeps, then remove it. On the screen it will ask you to plug your controller in and press the PS button, do so and you'll be presented with 6 options.
The first one you want to try is restore file system, this will check your PS3 for any errors on the hard drive, and correct them if they can. This may take a little while but let it run through and see if it works.
If not then move on to the next option, but BACK UP YOUR DATA BEFORE DOING SO, the next step will wipe your PS3 clean! Repeat the process above until you get to the menu and then select "Rebuild database".
Try these two first and let me know if it helps! :)
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is not showing the game picture on the main menu:(
its possable thats its the laser there is a method to restor the ps3 back to factor witch might correct any software problems that might cause the laser to malfuction be warned that doing this erase all your data and restores it to the orginal factor state or like brand new here are the steps
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format.. You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset
hope this helps and if you can i would back up your ps3
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
When the display is via HDMI Games won't load?
is your screen a full hd one ?
if not, verify your resolution settings in the ps3 system settings ; you may experience problems if you allow you system to run in a resolution not supported by your TV .
Jul 24, 2009 | Sony Playstation 3 (PS3) Console
Used PS3 will not recognize or play games or dvds
The dvd drive has a bad laser in it more then likely. Thats why it doesn't matter what disc your putting in so either the laser would be replaced or a whole new drive put in.
I would notify the seller on Ebay and get the system swapped out with another one or get your money back. Refurbished systems mean that something was wrong with it and parts were swapped out or either repaired down to component level. Sometimes the technician doesn't check out the system fully and thats why you can run into the problem that you have now.
May 23, 2009 | Sony Playstation 3 (PS3) Console
Ps3 40 GB upgraded to 160 GB but it won't work
yes very common problem with this harddrive..you must upgrade to a 60gbSATA
Sep 17, 2008 | Sony PlayStation 3 40GB System
Sony Playstation 3 (PS3) Console Logo
140 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
