Question about RELIANCE ELECTRIC WATER HEATER
How to change the temperature onmy hot water tank
Link below shows how to adjust on common type water heaters.
Other heaters can be different depending on brand and type
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
Posted on Jan 04, 2011
Electric tank water heater is in attic. When outdoor temps are high it doesn't work. Why?
Hi Jan:
Really interesting............
A puzzle I've never encountered before.
I'm a retired Contractor and Building and Plumbing Inspector so can offer an answer based on experience.
- In hot weather, attics get REALLY hot.
- An attic is an unusual location for a hot water tank.
- A thermostat senses the temperature of the water in the tank and determines when it needs to be heated.
- I would be suspicious that in your installation, the temperature in your attic is higher than the "high limit" for your water heater.
To phrase it another way, since the attic temperature is really high, and the tank thermostat is in the attic, it "thinks" that the water is already at the required temperature.
The only real "fix" that I could suggest would be to locate the hot water tank in the moderated temperature area of the dwelling.
Hope this helps.
I would appreciate your letting me know by comment to this post if that is the problem.
Cheers, and thanks for the puzzle.
Apr 24, 2016 | Water Water Heaters
Tip
How to Change the Gas Valve and Thermostat on a Hot Water Heater
<p>If you are having<b> trouble with the temperatures</b> of your <b>gas hot water heater</b> fluctuating too much, or after <b>changing the thermocouple</b> of your gas <b>hot water heater</b> then you may need to change the complete <b>gas valve and thermostat assembly</b>. Also if you have changed the <b>thermocouple</b> and the pilot still will not stay lit, then the gas valve could be bad or the <b>ECO (Emergency Cutout)</b> may have activated and is open. This is a onetime device and cannot be replaced.<br /> <p><br /> <p>These instructions are for the older style <b>gas valve and thermostat combination</b>. These commonly have a large red knob that adjusts the temperature of the water. Also note that the burner tube nut for <b>natural gas</b> is right hand thread, but if you have <b>LP or propane gas</b> the burner tube nut is left hand thread.<br /> <p><br /> <p>The newer <b>gas valve thermostat combinations</b> that have come out recently are similar, but they have a well in the tank that the sensor slides into. The assembly is held fast with a set screw. With this type of <b>gas valve and thermostat unit </b>the tank does not need to be drained, but most of the rest of the change out is similar.<br /><br />To change a <b>gas hot water heater thermostat</b> you will need to first buy a new gas valve for your <b>hot water heater</b>. The <b>gas valve</b> and the <b>thermostat</b> are integrated into one unit.<br /><br />To <b>replace the thermostat on a gas hot water heater</b> you must follow these procedures....<br /><br />1. Turn off the incoming water and<b> drain the hot water heater</b>.<br /><br />2. Remove the <b>pilot tube</b>, the <b>burner gas tube</b> and the thermocouple from the gas valve. Turn off the <b>gas line</b> and remove from the gas valve.<br /><br />3. Get a <b>pump pliers</b> or a<b> wrench</b> in behind the gas valve and turn the whole assembly CCW to remove it from the tank.<br /><br />4. After applying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the <b>ECO</b>. They are the little red wires on the back. If you break them the assembly is irreparably damaged.<br /><br />5. Reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.<br /><br />6. Fill tank with water. Make sure to open a <b>hot water faucet</b> and <b>purge all air from the tank.<br /><br /></b>7. <b>Check for leaks</b> where the gas line hooks up with soapy water.<br /><br />8. Relight pilot light and check operation.<br /><br />9. Set the new temperature setting to a medium setting and then adjust the temperature to your liking from there and adequate time for heating completely<br /> <p>
on Feb 25, 2011 | Water Heaters
Hot water heater has hot in tank but dose not come out of hot water line on tank
most electric hot water systems use a heat transfer process where the element is in one tank and the house water is in another
the house water is what is being drawn off when you turn on a tap
there is a regulator valve at the top of the tank with a small lever that you open up to let water in and air out of the system
another point is that there may be a hot/cold mixer on the hot water outlet which limits the temperature of hot water to prevent scalding injuries in the bath and shower or sink
If you have one fitted they are known to malfunction and cut the hot water temperature down as, they mix too much cold water into the hot water pipe.
have a plumber check it out
Jun 13, 2015 | Water Water Heaters
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
I have a GE Profile Water Heater Model #SE40M12AA01.
I recommend safety changes to prevent ruptured water heater and assorted leaks.
135 degree hot water.
Maybe replace TP valve if it is dripping.
Drip pan under water heater with 3/4" drain line to outside.
Expansion tank on incoming cold water line to absorb pressure build-up, and prolong life of tank and plumbing.
Here's why:
1) Yes you can have scalding hot water.
2) I recommend 135 degrees since that will burn the evil right out of ya. And generally kill clothes washing bacteria.
3) 150 is dangerous and can seriously burn skin in 1.5 seconds. Not safe around children and elderly.
4) Temperature settings on electric water heater are approximate, since thermostats are calibrated approximately, and read temperature through tank wall.
5) Also if you want to increase amount of hot water for high-consumption household, then setting tank temperature upward is one solution since more cold water is mixed with hot, so amount of hot inside tank goes further.
6) High temperature can cause TP valve to release water.
TP valve is pressure-temperature safety valve. Do NOT cap off.
Rating should be 125 psi and 180 degrees ... but all things water heater are approximate, and TP valves need replacement now and then.
It is not recommended by water heater manufactures to use 150 psi TP valve when water heater came with 125 psi. Rating shows in small print on end of TP. New TP valves sold at local hardware. Let tank cool before installing new one.
7) Higher temperature and high pressure can rupture tank.
Pressure over 80 psi shortens life of water heaters and plumbing fixtures. Put BTG100 pressure gauge on water heater drain valve to check pressure.
8) You need a drip pan with 3/4" drain line to outdoors, or to drain vent line, to prevent flood caused by ruptured water heater.
Turn water heater off when going on vacation.
Inspect water heater each 6 months.
Drip pan available at local home center or hardware:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#drip
9) Heated water expands and puts pressure on tank and pipes.
Water does not compress... so when water gets hotter it expands against tank wall and against pipes.
Especially in closed system (check valve present) when system is without expansion tank.
Expansion tank is installed on incoming cold water line.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#expansion
Oct 31, 2012 | Water Heaters
Electric water heater. water not hot enough
Check if tank is hot.
Open drain valve at bottom of tank, and then raise TP lever at top of tank.
If water is about same temperature both top and bottom, and water temp at tap is cooler, then turn up temperature, and check for crossover and broken dip tube.
If water in lower part of tank is very cool compared with top, then you want to test elements, replace thermostats, and clean sediment out of tank.
Add a comment as needed while you work on tank.
Sep 22, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Mt 6 gal. atwood hot water heater ignites but will not stop I put a new relief valve on it because it was leaking.
Excessive temperature from running too long will cause relief valve to open. If water temperature is too hot, thermostat & ECO should be changed. They are in behind that little foam cover where the letters are marked on cover. Check that they are up against tank good when you remove foam cover, as that may be the cause as well. They need to be held against tank, by the little coil spring and retainer. If they are against tank good, then replace them.
Dec 09, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Heat is on water is going in cold but not coming out hot copper coming out of tank is room temp;
Your gas valve may be faulty and need replacing as it is not sensing the change in water temperature in your hot water tank,
Feb 14, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hot water lasts half the time
How old is the heater?
It may be something as simple as just needing to flush the tank to remove any sedemints....and hopefully so because this is the easiest/cheapest thing to do.
If this is not the case go ahead and remove the heating elements and check for wear. Replace them if necessary. I would also replace the thermostats that accompany each of the elements.
Checking and replacing both of this requires you to drain the tank completely and should be close to $25 total....last time I checked.
Apr 27, 2009 | General Electric Water Heaters
Water Heater Repair
If steam or excessively hot water shoots out of faucets, or you hear boilding sounds inside the hot water heater, the appliance may not be shutting off at its set temperature. The job of the temperature- pressure (TP) relief valve is to release excessive pressure from steam buildup, but this valve may have been improperly installed, or it may be faulty. Either way, this condition can be dangerous, both because hot water and steam can scald people and because enough pressure could build up to rupture the water heater. Immediately turn down the water heater’s temperature setting and allow the water to cool.
Aug 27, 2008 | Emerson Part UWL Chrome Ultrasystem water...
RELIANCE ELECTRIC WATER HEATER Logo
214 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
