Question about Nuvico Apex Enterprise DVR AP-D1600 16 Channel MPEG4 Security Digital Video Recorder
Monitor and DVR operating. verticle colored lines appeared on monitor with a bar with green flashing dots. never happened before. what does it mean?
The camera screen whether in stand by mode or record mode has vertical bars and dots all over the screen. The dots and bars constantly flashes and the vedio recorded sample also bear the same disturba
I hate to say this, but you better look out or a new camera.
If it is a new camera, with warranty, just bring it back, but I think repairing this one will cost much more than it is worth.
Dec 29, 2013 | Cameras
Verticle lines/streaks down screen
The Display panel could be bad/damaged or the main board that controls every thing could be bad---parts for Dell equipment are known to be hard and sometimes impossible to find.
Dec 07, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Hello sir my samsung lcd monitor model no 740N . in dis monitor right side display two verticle lines green n light pink but hoe to i resolved dis problem please give me suggestion
You cant resolve it tiny resistors in the screen have failed and that is why the lines have appeared, it is a case of live with it or buy a new monitor
Feb 24, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I have vertical lines on screen I have changed the whole screen assembley but lines are still thers , exactly in same place
Hey There,
The reason this happens is because the graphics card is either loose burned out or jsut needs to be cleaned... to clean it use a pencil rubber in the gold tips that connect it, blow on the card to remove any dust build ups and reconnect the graphics card when done (make sure its clipped in properly).... different brands of computers will do different things such as the different coloured lines and screens flashing red. My dell latitude 630 had green and blue verticle lines. Just follow what i said and it should be fine
Hope this will help you in Resolving the issue with the vertical Lines on the screen.
Cheers!!!!!
Vivek
Feb 14, 2010 | HP Compaq nx6325 Notebook
Balck color turns into green
are the dots appearing in diagonal lines or randoml across the screen? This would suggest to me either a loose connection in your cable or the screen is faulty and will need replacing. Sorry for the bad news
Oct 25, 2009 | Computers & Internet
All of the sudden alot of red dotted verticle lines appeared on my screen and are on there constantly. Any idea what caused this or how to remove them?
Most likely if the line appear in all screens you have a hardware issue. Reseat the monitor connection, see if anything changes. If not, try monitor on another system or another monitor on this system, see if the problem follows the monitor or the system.
If the issue stays with the system, then you will likely need a new video card. If you have Intel Integrated video, try different RAM. If RAM makes no difference, a motherboard or an expansion video card will be needed to resolve.
Oct 19, 2008 | Gateway Computers & Internet
Verticle 'transparant' bars
Hi...there,
It's seems your panel damaged inside. Replaced a new panel gonna cost you more... So, just a new ones. Have a nice day!
Oct 01, 2008 | Computers & Internet
Laptop lcd screen
that's not a firmware issue..your lcd is starting a slow decay to final unhappiness..
you can try the old driver downloader trick, but it's just a matter of time now.
Feb 21, 2008 | LG Flatron L1750S 17" LCD Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Nuvico Apex Enterprise DVR AP-D1600 16 Channel MPEG4 Security Digital Video Recorder Logo
23 people viewed this question
Top Nuvico Home Security Experts
Lawrence Oravetz
Are you a Nuvico Home Security Expert? Answer questions, earn points and help others
