Question about Frigidaire Electric Dryer
Will not start. lights come on but no sound when I press start button
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 04, 2011
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Washer won't wash
sounds like you might have a bad control board or touch pad.....it should lite up...consult a techician localy..
Mar 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
JBL on rour stop working one hour later every time
Hi, I got my on tour a couple of months ago and it worked fine. But just recently it starts stopping emitting any sound one hour or so after I start it. No sound at all, and the light goes off too. If I press one of the buttons, the light will glim just once.
Aug 01, 2008 | JBL (JBLONTOUR) Computer Speakers
Frigidaire  Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
